12 Bolt Rebuild - Team Camaro Tech
 9Likes
  • 1 Post By Chevy68
  • 2 Post By Everett#2390
  • 2 Post By big gear head
  • 2 Post By slazisme
post #1 of 15 (permalink) Old Feb 3rd, 20, 07:27 PM Thread Starter
Jeff
12 Bolt Rebuild
Going to rebuild my 12 bolt posi. Looked at buying parts for my carrier, (clutches, side gears and spiders) then I found this Yukon kit, what is everyone’s thoughts?
https://www.ebay.com/itm/GM-8-875-Ch...ry!77365!US!-1
X1169B likes this.
Thanks,
Jeff
1968 Camaro
Chevy68 is online now
post #2 of 15 (permalink) Old Feb 4th, 20, 05:34 AM
Freddie
Re: 12 Bolt Rebuild
Your old Eaton Posi is stronger than the Yukon Dura Grip. I'd recondition it and keep it. If the parts in your Eaton are still good then there is no need to replace them. Many times all you need to do is shim the clutches to restore the preload.
'69 RS/SS396 pro street/427/4spd/9"
big gear head is offline
post #3 of 15 (permalink) Old Feb 4th, 20, 06:03 AM
Re: 12 Bolt Rebuild
Why a rebuild? Jack up one wheel of rear axle, leave trans in neutral.
Apply torque wrench onto a lug nut and rotate the one tire with opposite tire on the ground.
You are testing the tightness of the clutches. Torque to 'break loose' the clutches is a minimum of 35 ft-lbs.
If the axle passes this test, just change oil and add GM clutch additive.
Chevy68 and wireboy355 like this.
Doing a good job is like peeing in your dark pants … you get a warm feeling, but nobody notices
post #4 of 15 (permalink) Old Feb 4th, 20, 07:09 AM
Rick
Re: 12 Bolt Rebuild
Don’t over do the Posi additive. It can get too slippery and interfere with the clutch lock up.
69 COPO clone, 461" BBC 11.25:1 Compression
840 Rec Heads (2.25/1.88) AED 850 HO carb
Orig Exhaust Manifolds
Straub (Clay Smith) cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is online now
post #5 of 15 (permalink) Old Feb 4th, 20, 10:39 AM
Re: 12 Bolt Rebuild
Just install heavier springs. Standard rate for the springs is 50 lbs/inch. GM sells, or used to, 75 lb springs.
I would like to say, yellow springs are standard and green are heavier rate.
post #6 of 15 (permalink) Old Feb 4th, 20, 04:24 PM
Re: 12 Bolt Rebuild
I agree with the spring change
69z28302 is offline
post #7 of 15 (permalink) Old Feb 4th, 20, 04:44 PM
Freddie
Re: 12 Bolt Rebuild
You don't need heavier springs if the clutches are good and shimmed correctly.
Everett#2390 and rp930 like this.
post #8 of 15 (permalink) Old Feb 4th, 20, 04:57 PM
Brett
Re: 12 Bolt Rebuild
Everett, What a great tip. I might be tipping my knowledge (or lack of it) but I had never heard of that. I will go try it out on my newly installed used 12 bolt as soon as I can.
Thanks,
Brett......
Rockets Up In 2020!
Brettallen59 is online now
post #9 of 15 (permalink) Old Feb 4th, 20, 08:17 PM Thread Starter
Jeff
Re: 12 Bolt Rebuild
Thanks Freddie, that what I was thinking that the Eaton unit was superior.
It always starts off as a simple project. had leaky axle seal, changed bearings and seals. Thrust washer fell out trying to install pin. Noticed pitting on the spider and side gears and what looks like debris marks on both sides of the thrust washers. Current plan is to pull the carrier and clean and inspect everything.
Just exploring options and best route once the inspection is completed.
Everett, thanks for the tip on using a torque wrench.
Thanks,
Jeff
1968 Camaro
post #10 of 15 (permalink) Old Feb 5th, 20, 07:14 AM
Re: 12 Bolt Rebuild
You're welcome, straight from the Chevrolet Service Manual
Chevy68 and Just 1 More like this.
post #11 of 15 (permalink) Old Feb 5th, 20, 08:48 AM
Re: 12 Bolt Rebuild
I went with the Yukon set up and axles and it turns out that the axles have a larger inner stand-off than mosier, strange or stock replacements so I had to get my rotors machined. Then I had to get the caliper brackets machined since the axles stick out slightly further than the aforementioned brands. Not the end of the world but it was annoying.
AZ_Bill is offline
post #12 of 15 (permalink) Old Feb 5th, 20, 09:02 AM
Simon
Re: 12 Bolt Rebuild
I have this on file, shows how to rebuild a Eaton posi, he also sells all the parts needed to rebuild.
Good video to know the inner workings.
HawkX66 and Chevy68 like this.
slazisme is offline
post #13 of 15 (permalink) Old Feb 5th, 20, 12:13 PM
Larry
Re: 12 Bolt Rebuild
I never knew those specs existed!
Chevy68, be aware that a special tool is used in the service manual to attach the torque wrench in the center of the hub. You should be able get accurate readings if you orient the wrench at a tangent to the hub, (90 degrees from the centers of the hub and the stud.)
Just in case you weren't aware...
Current Project:
69 Z/28 Resto-Mod
Next In Line:
83 Z28 Restoration
69-er is offline
post #14 of 15 (permalink) Old Feb 5th, 20, 07:10 PM Thread Starter
Jeff
Re: 12 Bolt Rebuild
Funny how these simple little project turn into big projects!!!
Thanks,
Jeff
1968 Camaro
post #15 of 15 (permalink) Old Feb 5th, 20, 07:12 PM Thread Starter
Jeff
Re: 12 Bolt Rebuild
Just in case you aren't aware...
Thanks for the heads up. I do have a 3- hole puller I could use to center on he hub.
Thanks,
Jeff
1968 Camaro
