Original Radiators - Team Camaro Tech
post #1 of 15 (permalink) Old Feb 22nd, 07, 11:23 AM Thread Starter
Vince
Question Original Radiators
Radiator shop is telling me that can't rebuild my UG code radiator from my all orig 67 vert. They can replace the core for $300? Sounds pricey.............my radiator wasn't even leaking but it also had never been out of the car before.
Ideas??
3forme is offline
post #2 of 15 (permalink) Old Feb 22nd, 07, 11:49 AM
Vintage 68's Avatar
Cool Re: Original Radiators
Yeah, a recoring job has gotten pretty pricey lately - might be something else I look into doing my self sometime. ( I have redone some older truck radiators BITD using a 55gal drum)
I still have a shop that will recore them for me using a Desert Cooler brand core from U.S. Rad.
I usually ask for a #10906 core for most performance cars that have the wider 2 5/8" core. Haven't had one heating problem yet with this core.
They also still manufacture the OEM style 1/2" tubes on 9/16" centers in 2" & 2 5/8" thickness if you want a core exactly like original - just ask them for the correct stock number by width and tube count.
Costs have run anywhere from the low $200's to the mid $300's lately.
(edit) oops - should have thrown this link in for ya - http://www.usradiator.com/default.htm
1968 Convertible
Some trucks
Last edited by Vintage 68; Feb 22nd, 07 at 11:51 AM. Reason: put link from favorites ...
Vintage 68 is offline
post #3 of 15 (permalink) Old Feb 22nd, 07, 11:53 AM
3forme,
An original Harrison radiator is about $900 to $1,000. Three hundred for parts & labor is not bad at all. That's about what I would expect it to be. I have a 1969 without the original radiator. I was looking at close to the same price for mine. You can buy a new radiator for that kind of money. I replaced my small block radiator with a big block radiator. However, I know originality is important to you, especially in your case. For $300 I would have them replace the core. That way you keep the UG radiator in place without having to spend $900 or $1,000 for a new original Harrison. The UG is tougher to find as well.
1) 1969 Camaro RS 396 TH 400, 12 bolt 3:73 sold 1994
2) 1984 Z28, 5.0 H.O. T-Tops, G92 3:73, sold 1994
3) 1988 5.7L IROC-Z, sold 1994
4) 1969 Camaro bought 2006, back on the road in 2010
post #4 of 15 (permalink) Old Feb 22nd, 07, 12:27 PM Thread Starter
Vince
OK, thanks very much for the input I'll have a new core put between my old tanks. Thanks again.
Vince
3forme is offline
post #5 of 15 (permalink) Old Feb 22nd, 07, 12:29 PM
Jeff
Make sure they don't use a flat sided core.
Looks funny IMO.
My shop down here custom made a core for me -
with ribs on the sides very close to the originals.
The problem is that the new EPA regulations FORBID boiling out the radiator cores like was done in the past.
Not so nice for original cars like ours.
Pacecarjeff is offline
post #6 of 15 (permalink) Old Feb 22nd, 07, 01:23 PM
Rob
satz28's Avatar
Jeff, Why is this?
Rob
Sold 6-1-2014 after owning the car for 18+ years
69 Z-28 X-77 HO * DZ Put away * M20 * 4.10
406 CI * CC XR274R 236/[email protected] 564/570 110 LSA/106 ICL * Brodix IK 200
475 HP, 495# tor
Street Tires, Full Exhaust Sep 07 -12.68 @ 113 MPH * Street Tires, Open Headers Oct 08 - 12.65 @ 116.2 MPH
satz28 is offline
post #7 of 15 (permalink) Old Feb 22nd, 07, 01:27 PM
Jeff
The lye/acid chemicals that were used are not allowed anymore.
The EPA inspectors came around a few years back, and made the shops dismantle the boiling pots.
At least this is what happened in Florida.
I heard rumors of others that may still do this,
but I could not find anyone local who would.
post #8 of 15 (permalink) Old Feb 22nd, 07, 03:25 PM
Pat
Kind of becoming a lost art as well. I found an old school guy to recore mine like you're having done,he said that now so many radiators are plastic core and basically cheaper to replace than fix, that alot of radiator shops are out of business.I can believe it cause a number of radiator shops that were open for years in my area have closed.Mine was $325...but he put 5/8ths tubes in it with a factory look...he recommended the 5/8 cause I'm adding air to the car and it always ran a little hot withou the air so I took his suggestion...but I think your guy is in the ballpark as far as price
67pat is offline
post #9 of 15 (permalink) Old Feb 23rd, 07, 04:29 PM Thread Starter
Vince
Well I went to pick it up and the UG tag is missing How do you say I'm gonna strangle you in spanish????
3forme is offline
post #10 of 15 (permalink) Old Feb 23rd, 07, 10:54 PM
Bill
Yeah, the recore prices have jumped plenty in the recent past due to the fact that the govt has dibs on all copper and brass.. I guess it's just another way for the taxpaying public to pay for the war overseas.
69 Camaro X11 SS clone 79B Ralley Green
66 Caprice 396 Tropic Turquoise.. in progress
Amptech is offline
post #11 of 15 (permalink) Old Feb 24th, 07, 08:15 AM
¿Por qué quitó usted la etiqueta de UG? Usted pone mejor lo apoya o patearé su asno.
TC # 349
zdld17 is offline
post #12 of 15 (permalink) Old Feb 24th, 07, 04:40 PM Thread Starter
Vince
That is too funny Don, that cracked me up. They called me at work today to say they drained their tank and found my tag so I'm much happier now but your post was classic
3forme is offline
post #13 of 15 (permalink) Old Feb 24th, 07, 05:42 PM
Kevin
KevinW's Avatar
That did not translate too well from the free sites on the web
"Why cleared you you label it of UG? You put better supports it or I will kick your a**."
I take my tags off before I give them out!
Kevin
KevinW is offline
post #14 of 15 (permalink) Old Feb 24th, 07, 06:08 PM
Well the lesson learned from it will be they wont do it again and I hope there are other shops in your area. Come to think of it, the tags are soldered in the lips? But you got your tag back to thats worth only a half can of whooping. Hope they did not drain the entire vat of muric acid for this.
TC # 349
zdld17 is offline
post #15 of 15 (permalink) Old Feb 24th, 07, 06:17 PM
Kevin
KevinW's Avatar
Yes the tags are soldered. But a little heat from a propane torch and they pop right off.
Kevin
KevinW is offline
1968 Z-28 Original 1/4 Mile Times GOSFAST Performance 9 Mar 6th, 06 06:20 PM
original 67 kick panels glued in??? HELP!! bigredbrad Restoration Corner 3 Feb 13th, 06 08:34 AM
Restoring original 327 motor 19HoosierDaddies67 Restoration Corner 2 Dec 24th, 04 02:25 AM
Original V.S whatever summit ect 67-68 knightmoose2000 Tech 2002 0 Aug 30th, 02 04:18 AM
