air conditioning problems - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 22nd, 07, 03:27 PM Thread Starter
1997 camaro v-6 Not getting power to the compressor clutch checked all fuses blower works but no compressor.thanks gary
gary lee is offline
post #2 of 7 (permalink) Old Feb 22nd, 07, 04:18 PM
john
wagonman's Avatar
Re: air conditioning problems
low freon therefore not closeing the low pressure switch?
blown fuse?
have you checked these conditions?
wagonman is offline
post #3 of 7 (permalink) Old Feb 22nd, 07, 04:24 PM Thread Starter
thanks ck all fuses willck freon gary lee
gary lee is offline
post #4 of 7 (permalink) Old Feb 23rd, 07, 06:38 AM
spring is coming.
AC shops run service specials,,,, USE them, Spend the $30, since you have absolutely no knowledge at this time about AC systems.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
hhott71 is offline
post #5 of 7 (permalink) Old Feb 23rd, 07, 03:26 PM
not alot to know about ac systems...not a magical land where unicorns roam and knomes play tricks on trolls...lmao...you have a high pressure switch, a low pressure switch, a compressor clutch, a switch , a relay and a fuse...you can het a haynes manual for 15 bucks, and follow the schematics to diagnose the electrical end of it...r-134 is redily available at the local walmart, and is the usual suspect for making the low pressure switch open and cause the compressor not to function...
kustomwerker is offline
post #6 of 7 (permalink) Old Feb 23rd, 07, 05:21 PM
On my '94 if it is low on freon it will set a trouble code and the compter needs to be reset before the compressor will be turned back on I have done this by disconnecting the battery for a short time.
TTFN
Mat
SSCARGO
Mat Klemp is offline
post #7 of 7 (permalink) Old Feb 24th, 07, 06:56 AM
that also happens on obd2 vehicles, and you cant reset the code by disconnecting the battery on them...(obd2)you can on your vehicle though...(obd1)
Painting basics MARTINSR Body Shop 13 Jun 24th, 16 02:02 PM
heater only in a factory air 69 gschuld Heating & Cooling 1 Nov 21st, 06 10:43 PM
Vintage Air vs Classic Auto Air systems [email protected] Heating & Cooling 14 Sep 15th, 06 06:02 AM
Understanding the AIR PUMPs pupose Jays92CamaroRS Camaro Tech 10 Jun 11th, 06 04:26 PM
Adjusting High Speed air bleeds DZ Fool Performance 4 May 2nd, 05 02:01 PM
