Kick Panel Vent Seal Replacement - help - Team Camaro Tech
post #1 of 2 (permalink) Old Mar 30th, 07, 08:41 PM Thread Starter
I received my replacement non-AC kick panel vent seals (KP-16) from Rick's today, and I am not thrilled. The foam is wider than original in the narrow dimension, which is fine, but it is about 3/16" too short in the long dimension, which means it will let air past the top and bottom when closed.
There is no manufacturer indicated on the bag, so I don't know where it came from.
So, two questions:
1. Has anyone found repro non-AC kick panel vent seals that are the right size and shape?
2. Does anyone know where a guy could get closed cell foam 1/8" thick and at least 6" wide by 9" tall?
Eric
Eric Kammerer is offline
post #2 of 2 (permalink) Old Mar 31st, 07, 07:48 PM
jim
Re: Kick Panel Vent Seal Replacement - help
i made mine from an old fender cover. works fine.
262jp is offline
6.5" speakers in kick panel 67FamilyFun Interiors 0 Jun 29th, 06 07:47 PM
kick panel speakers distaz Restoration Corner 2 Dec 3rd, 05 08:27 PM
Deluxe Kick Panel Leak Seakane Interiors 19 Jun 11th, 05 06:51 PM
Patch Panel replacement 69vert Body Shop 5 Aug 28th, 03 05:44 PM
Convertible Header Seal Replacement 68.camaro Body Shop 1 Aug 14th, 01 06:09 AM
