Help! A/C Blows Hot Air - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 2nd, 07, 02:24 PM Thread Starter
I have a 2000 Camaro, 3.8 liter. The a/c only blows hot air. I checked to see if it needed freon but it does not. What could be the problem? Is thier anyway I can troubleshoot if so, for I can avoid being ripped off by an a/c repair shop.
dejr3815 is offline
post #2 of 5 (permalink) Old Apr 2nd, 07, 03:20 PM
Kevin
SixtyAte's Avatar
Re: Help! A/C Blows Hot Air
This may sound dumb but did you move the lever from HEAT to COLD ?
Kev
SixtyAte is offline
post #3 of 5 (permalink) Old Apr 2nd, 07, 05:10 PM
Tony
I had the same problem with a newer vehicle. Something got trapped in the plenum door, and it wouldn't move to allow cold air in. I had to end up replacing the inner box.
tonycamaro is offline
post #4 of 5 (permalink) Old Apr 2nd, 07, 06:06 PM
how much pressure you got with a/c not runnung in system you need at least 60-90 with a/c off. when you turn on need to check for power at a/c compressor. no power than need to go to low side switch and see if power there.power flow-fuse-pressure switch-low and high side= than to compressor. anything missing between no a/c.
jaguareats is offline
post #5 of 5 (permalink) Old Apr 2nd, 07, 11:05 PM
Dale
wow... ripped off, all I have to say.
68 Dana 302, 68 rs 327 daily driver/family car, 71 rs, track car/ driver, 68 firebird 400, 70 formula 400, 73 type LT, 98 TA, 2 goofy kids and an incredible wife.
dale68z is offline
Painting basics MARTINSR Body Shop 13 Jun 24th, 16 02:02 PM
hot air choke on new manifold ec68 Engine 3 Mar 11th, 07 06:14 PM
AC vents always blowing hot air DPeter2101 Heating & Cooling 5 Nov 28th, 06 05:08 PM
Q-jet hot air choke BAMiller Engine 0 Aug 2nd, 06 06:19 PM
hot air jbird Heating & Cooling 4 Aug 29th, 05 05:38 PM
