What Size Is A 67 Ss350 Temp Sending Unit??? - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 7th, 07, 08:29 AM Thread Starter
DeAngelo
I have a 67 SS 350 and just replaced the original motor with a 383. The new temp sending unit on the 383 does not work with my temp gauge in my console gauges (original type gauges). I want to use the old sending unit but am unsure about its size. I think it is 3/4". I also don't know what size the opening is in my Professional Products Crosswind (Airgap Clone) manifold. I also have Holley aluminum heads and don't know the size of the hole in them. I would like to know where the old unit will fit..in the manifold or in the head. Thanks!
Deangelo66 is offline
post #2 of 5 (permalink) Old Apr 7th, 07, 01:10 PM
Re: What Size Is A 67 Ss350 Temp Sending Unit???
your stock sender is 1/2" NPT, and the hole in the head is probably 3/8"NPT.
the holes in the intake should be 1/2" NPT, so the sender should fit there.
another option is to get a gauge sending unit for a late 80's pickup truck and put it in the head.
you don't plan sincerity.
novaderrik is offline
post #3 of 5 (permalink) Old Apr 8th, 07, 03:35 PM Thread Starter
DeAngelo
Thx, Derrik. Will the resistance of a late 80's truck sending unit we be the same? Will it be accurate for my factory gauges? What year, make and model truck should I use? Thx! D
post #4 of 5 (permalink) Old Apr 8th, 07, 03:57 PM
i believe all GM gauges work the same.
ask for a temp sender from an 86 or so pickup with a 350.
post #5 of 5 (permalink) Old Apr 8th, 07, 06:37 PM Thread Starter
DeAngelo
Thx, Derrik!!! D
temp sending unit A69RS Tech 2000 9 May 9th, 06 10:15 PM
themp sending unit location mr. black Heating & Cooling 5 Oct 1st, 04 12:34 PM
Temp Sending Unit vs Resistor dschribs Electrical & Wiring 5 Aug 12th, 04 04:43 PM
water temp sending unit denverRS/SS Tech 2000 1 Mar 5th, 01 08:55 AM
WATER TEMP SENDING UNIT HOTROD69CAMARO Tech 2000 1 Feb 8th, 01 06:59 AM
