Would this create a problem ? - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 10th, 07, 04:17 PM Thread Starter
Steve A.
flat350's Avatar
Send a message via AIM to flat350
Question Would this create a problem ?
68 with a big block radiator and a small block motor . The upper radiator hose is above the top of the tank about where it turns to go to the goose neck , all of the hose is above the tank not just a portion of it . Could this create an air pocket and not let the coolant circulate freely ? If so is there a part number for a correct hose that would work .
flat350 is offline
post #2 of 10 (permalink) Old Apr 10th, 07, 05:03 PM
Harry
dawg's Avatar
Re: Would this create a problem ?
im unsure but I would think it would trap some air.
I would look at some of the aftermarket hoses to find your fix
434 stroker
US Navy retired
dawg is offline
post #3 of 10 (permalink) Old Apr 10th, 07, 05:03 PM
The air should be flushed through the system.
68 Camaro~LSx ~all motor
post #4 of 10 (permalink) Old Apr 10th, 07, 06:21 PM
in 68, a small block a/c car also used the 23" radiator, so that hose would be a proper fit for your application
post #5 of 10 (permalink) Old Apr 10th, 07, 06:26 PM Thread Starter
Steve A.
flat350's Avatar
That's kind of what I was looking for , I know the hose that's on it now is just something that almost fits but not right .
flat350 is offline
post #6 of 10 (permalink) Old Apr 10th, 07, 10:13 PM
maybe you can trim it a bit on the outlet side to get the hose down lower.
but i really wouldn't worry about it.
you don't plan sincerity.
novaderrik is offline
post #7 of 10 (permalink) Old Apr 12th, 07, 04:58 PM
I run a small block with the BB AC rad and I love it. Since the swap it never runs hot. No problems.
John68rs is offline
post #8 of 10 (permalink) Old Apr 13th, 07, 08:52 AM
If your concerned about air in the system, put a catch can on it. It should bleed it out after a while
69 cranberry red convertible
LT1 4L60E NY "BADASELL"
red69camaro is offline
post #9 of 10 (permalink) Old Apr 16th, 07, 05:50 PM
I run a 23 inch big block radiator on my 68 327 with a/c and a catch can, no problems, love it.
68 convertible
ccpeat is offline
post #10 of 10 (permalink) Old Apr 17th, 07, 12:19 AM
Steps
Think about it...there is NO WAY you will ever get the air "traped" in it AND it doesnt matter to hoots...
This is where the water pours goes INTO the radiator, and what is in the top of the radiator?....an air space.
As to being too big...not a problem, it is the thermostat that determines in Min running temp.
Steptoe is offline
intermittent starting and running problem boz2841 Engine 6 Apr 5th, 07 08:58 AM
In Need Of Major Help!! Please!! Justgotacamaro Engine 31 Mar 6th, 07 05:22 AM
intermittent starting and running problem boz2841 Electrical & Wiring 1 Feb 22nd, 07 01:45 AM
intermittent starting and running problem boz2841 Fourth Generation 0 Feb 21st, 07 07:00 PM
Air Conditioning Problem Mark C Heating & Cooling 21 Jul 17th, 05 10:16 AM
