slim line dual radiator fan - Team Camaro Tech
post #1 of 18 (permalink) Old Apr 17th, 07, 08:15 PM Thread Starter
Marc
Anybody have any recommendations on a slim line dual radiator fan for a 1st gen Camaro?
Marc
67 Camaro, 454, TH400, 9" 4.11's
camaro man is offline
post #2 of 18 (permalink) Old Apr 17th, 07, 10:22 PM
Harley D
HarleyD67's Avatar
Re: slim line dual radiator fan
Flex-a-lite 210 dual 12" fans. It only pulls @ 20amps, moves @2500 cfm, and has it's own shroud for about $250.
"Be who you are and say what you feel, because those mind don't matter, and those who matter don't mind."-Dr. Seuss
We learn life's important lessons in kindergarten.
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
HarleyD67 is offline
post #3 of 18 (permalink) Old Apr 18th, 07, 06:31 AM Thread Starter
Marc
I'm currently running a Perma-Cool 16" fan pulling 2950 without a shroud. Would the Felx-a-lite 210 be better since it has a shroud? My 16" was great till I added my ProCharger. Now I think the intercooler is hindering the flow of air through the radiator.
Marc
post #4 of 18 (permalink) Old Apr 18th, 07, 08:57 AM
I have dual Spal fans. They are really tight.
502prostreet is offline
post #5 of 18 (permalink) Old Apr 18th, 07, 09:12 AM Thread Starter
Marc
The 210 is too big for my radiator. The radiator core measures 18" x 22". The 210 requires 15 1/2" x 26 1/4".
Marc
post #6 of 18 (permalink) Old Apr 18th, 07, 09:25 AM
Harley D
HarleyD67's Avatar
In that case either get or make a shroud for your existing fan. It moves enough air just not through the whole radiator.
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
post #7 of 18 (permalink) Old Apr 18th, 07, 10:27 AM
I have the 23" wide radiator in my car. (a 1969 Camaro). This is the BBC radiator. I recently installed a Flex-A-Lite Black Magic Extreme fan. It is The FLX-180. It comes with it's own shround and does not interfere with the water pump. The universal mounting brackets definitely do not make the fan look correct but hey the thing fits, it's one huge fan and it flows 3300 CFM. The built in shroud covers nearly the whole radiator. Maybe an inch or so shows on each side and maybe 1/4 inch top or bottom. Nice fit!!
You can buy it at Summit or Jegs. It took longer for me to figure out how to mount it with those ugly & stupid brackets than it did to install the wiring on it. The wiring was easier than I thought. It only draws 18 Amps unlike the Lincoln Mark VIII fan which could be as much as 100 Amps on start up and requires a separate controller. I run the adjustable thermostat on mine and I like it so far.
The price has jumped up about $50 or $60 since I bought mine about three months ago. Here are the Summit & Jegs links
http://store.summitracing.com/partde...0&autoview=sku
http://www.jegs.com/webapp/wcs/store...0002_312482_-1
1) 1969 Camaro RS 396 TH 400, 12 bolt 3:73 sold 1994
2) 1984 Z28, 5.0 H.O. T-Tops, G92 3:73, sold 1994
3) 1988 5.7L IROC-Z, sold 1994
4) 1969 Camaro bought 2006, back on the road in 2010
post #8 of 18 (permalink) Old Apr 18th, 07, 01:06 PM
madmax87's Avatar
Here's the dual spal setup on my SBC. Worked great.
madmax87 is offline
post #9 of 18 (permalink) Old Apr 19th, 07, 07:37 PM Thread Starter
Marc
Thanks for the input. I decided to go with the Flex-A-Lite Black Magic Extreme FLX-180. I will let you guys know how it works out.
Marc
post #10 of 18 (permalink) Old Apr 20th, 07, 03:36 PM
Apprentice
Where did you get your spal fan set-up?
Kilr67 is offline
post #11 of 18 (permalink) Old Apr 21st, 07, 01:07 AM
madmax87's Avatar
It was originally part of the BeCool setup I had in the car. I had issues with the radiator and bought a Alumitech radiator and had them install the mounting bolts on the radiator to fit the fans. That way there were no overhanging brackets on top of the radiator. I believe Jegs or Summit sell just the fans and wiring kits.
madmax87 is offline
post #12 of 18 (permalink) Old May 14th, 07, 05:54 PM Thread Starter
Marc
I installed the Flex-A-Lite Black Magic Extreme FLX-180 and I'm still having issues with the system running hot. I'm currently running a large hot water restrictor instead of a thermostat. It's the same one I ran before the Procharger and it worked fine then. The water never got over 190. Now it's running 220. I think I'll try a smaller restrictor.
Marc
post #13 of 18 (permalink) Old May 16th, 07, 07:16 PM
67 455 Bird ragtop's Avatar
4th Gen T/A dual setup. Cheap from your local yard. Fits well on a 28-31" radiator. Draws only around 20 amps. 2500 cfm.
67 'Bird vert 455 JW TH400 KRE d-port 310 cfm heads H-beam rods Comp Cam 305-AH-8 cam w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Radials 31x18x15 on Convo Pro 15x15s
67 455 Bird ragtop is offline
post #14 of 18 (permalink) Old May 16th, 07, 08:21 PM
Jon
Rodder's Avatar
Send a message via AIM to Rodder Send a message via Yahoo to Rodder
That's what I'm running. I'm running a stock style 4-core radiator, and trimmed down a '99 Camaro SS (Z28 & T/A are the same) fan shroud to fit. I still need to make some brackets--it's zip tied right now. One neat trick for dual fans is to wire them with a 3 relay setup just like the 4th Gen. The third relay switches the fans between running in series and parallel, giving you two speeds. In the low speed mode, the fans use half the power and make half the noise.
- LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost
Rodder is offline
post #15 of 18 (permalink) Old May 17th, 07, 05:08 AM
Rodder - Care to give a little more info on how you did this ?? schematic or simple pencil drawing ??? I was thinking about using the new SPAL controller.
cooling line route? kencar69 Transmission & Driveline 11 Apr 27th, 06 07:23 AM
Fuel Pump Line Fitting?? 67 Convertible Engine 4 Apr 20th, 05 04:46 AM
Dual Fuel line owners, need parts? click Bench Racing 6 Jul 21st, 04 12:38 PM
Steel vs. Rubber fuel line englemac Engine 6 Oct 15th, 01 08:18 PM
Can I convert my 1/4 vent/return line into a 14psi return line for TBI unit??? snflupigus Tech 2000 3 Jun 13th, 01 03:57 PM
