Radiator Capacity Question - Team Camaro Tech
post #1 of 7 (permalink) Old Apr 18th, 07, 06:27 PM Thread Starter
I tried doing a search on the subject in this forum and didn't find any hits. Didn't find my answer on the CRG site either. Simple enough question though - is the radiator capacity for a small block motor with an automatic transmission less than it is for the same motor with a manual transmission? Looks to me like one of the side tanks has a fair amount of space reserved for tranny fluid to flow through. Just curious.
1967 Plain Jane Coupe - and proud of it!
Mountain Green w/Black Bumblebee
Mark Rossiter is offline
post #2 of 7 (permalink) Old Apr 18th, 07, 09:59 PM
Re: Radiator Capacity Question
My books do not show a different coolant capacity for auto vs manual trans radiators. The only differences shown are for A/C car vs Non-A/C cars. Does that help at all??....Jb
Beat it to Fit, Paint it to Match!
Johnny B is offline
post #3 of 7 (permalink) Old Apr 18th, 07, 10:40 PM
I would think that the only difference in radiator capacity between manual or auto trans versions would be the space taken up by the trans cooler.
red67camaro is offline
post #4 of 7 (permalink) Old Apr 19th, 07, 08:51 AM
Harry
dawg's Avatar
hmm so what is the capacity of a smallblock non a/c radiator?
434 stroker
US Navy retired
dawg is offline
post #5 of 7 (permalink) Old Apr 19th, 07, 11:55 AM
It should be the same. In my book it shows 14 qts. or 3.5 gallons for both.
Camaro buds until the end!!!
Camaro Dave is offline
post #6 of 7 (permalink) Old Apr 19th, 07, 06:55 PM Thread Starter
Yes, every response helps. I replaced my lo-perf automatic tranny with a Muncie 4-speed many years ago. I had cause to pull my radiator a week ago and I was reminded of the remnants of the tranny cooling line fittings still sticking out of the passenger side of the radiator tank. I thought I had plugged the holes, but when I took a closer look I realized that I just cut off the lines close to the fittings. That's when it dawned on me that I have a big fat empty chamber on that side of the radiator. Got me to wondering what the radiators are like for manual transmissions and if that big empty chamber is actually not empty.
post #7 of 7 (permalink) Old Apr 19th, 07, 11:00 PM
1st gen Camaro Cooling System Capacities.....as published by Mr Chilton!
1967 . Heat - A/C
250 . . . 14 - 14
327 . . . 15 - 18
350 . . . 17 - 17
396 . . . 23 - 23
1968
250 . . . 12 - 12
302 . . . 16 -
327 . . . 16 - 16
350 . . . 16 - 16
396 . . . 23 - 23
1969
250 . . . 13 - 13
302 . . . 17 -
307 . . . 17 - 18
327 . . . 16 - 16
350 . . . 16 - 17
396 . . . 23 - 24
Johnny B is offline
One question Test zuma Off Topic 3 Jan 10th, 07 07:14 PM
Engine Harness Question ironhorse78247 Electrical & Wiring 8 Nov 17th, 06 09:16 AM
am fm radio question flyers69 Electrical & Wiring 3 Jun 28th, 05 08:31 PM
carb and exhaust question for 67 RS small block Kyson Engine 2 Jun 25th, 05 12:40 PM
69 fuel line question - vapor return or not? Eric Kammerer Engine 7 Jun 11th, 05 06:08 PM
