Water Pump Choices - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 20th, 07, 05:04 PM Thread Starter
Jeff
Water Pump Choices
I am running a 383 with a BeCool aluminum radiator and dual electric fans with a 180 degree thermostat. When sitting and idling in hot weather, (Route 66 in Summer) it starts to run hot. I am currently running a stock Chevrolet water pump with a serpentine belt system. I was considering upgrading my water pump to a Edelebrock Victor Series to flow more water through the radiator.
Does anyone have any experience with this water pump, or another they can recommend to move more water to try and keep it cooler? Any other suggestions are appreciated.
Thanks,
Jeff
Cruzn69r is offline
post #2 of 4 (permalink) Old Apr 20th, 07, 05:55 PM
Re: Water Pump Choices
if you put a smaller pulley on water pump it will turn faster thus turning more water.maybe some other problem like fans not turning fast enough.you need to touch top hose when hot and touch bottom hose to see if big difference. than fans are fine.also try a 160 thermostat.also if radiator cap is no good it will run hot also. because of not building up pressure. no pressure it will run hotter also.look at what radiator says of pressure you should have a cap for.
jaguareats is offline
post #3 of 4 (permalink) Old Apr 20th, 07, 06:36 PM
I use a Wiand alluminum pump, it was in stock and the ede wasn't. was cheaper too. Cools great.
I would stay with a 180 stat. If it's running above the stat temp, a lower temp stat won't change a thing.
Also would wonder about the pulley ratio on your serpentine system?
Do you have a Richardson / Mr. Gasket high flow thermostat in it?
post #4 of 4 (permalink) Old Apr 20th, 07, 07:36 PM
Smile Re: Water Pump Choices
First of all, does your serpentine system require a reverse rotation water pump ? If so, it may be running backwards. I swear by Stewart water pumps. Check them out.
TJS69 is online now
327 with short water pump and running the fuel line woes 30lbtest Engine 12 May 3rd, 07 02:05 PM
short water pump or long water pump??.... PLT-1 Engine 5 Jan 28th, 06 08:47 AM
Water Pump 62bakes Engine 5 Nov 5th, 03 05:55 PM
Water Pump Woes… Z28 Mark @home Performance 7 Nov 5th, 02 03:38 PM
short water pump vs long water pump mark67ss Tech 2001 13 Oct 18th, 01 05:45 AM
