what's the correct operating temp - Team Camaro Tech
post #1 of 13 (permalink) Old Apr 21st, 07, 04:15 PM Thread Starter
I have a 327 30over - 180f tstat - what should I expect for normal operating temp? I took a ride today and it wnet up to about 210 maybe a little higher - but it stayed right there never climbed higher never dropped lower. Is this right?
TSTONE is offline
post #2 of 13 (permalink) Old Apr 21st, 07, 08:52 PM
Re: what's the correct operating temp
i wouldn't worry about that temp.
after all, water boils at 212 degrees at sea level- at 15psi, it boils at closer to 240ish.
you don't plan sincerity.
novaderrik is offline
post #3 of 13 (permalink) Old Apr 21st, 07, 09:18 PM
Pat
Mine ran at 210 no matter what T-stat I had in it...it just liked that 210
67pat is offline
post #4 of 13 (permalink) Old Apr 22nd, 07, 06:13 PM
george
I have a 427 .030 over with a 180 stat.My dual flexalites turn on at 200f and off at 185F.Not once did my coolant temp exceed 200F in stop and go thru Royal Oak.Down Woodward the temp hovers around 185F.Unless the 327 is radical..you sound like you need more capacity.If the small block struggles at 75F ambient...summer heat may be an issue for you.
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
post #5 of 13 (permalink) Old Apr 24th, 07, 06:12 PM
Darrell
if its not running close to what thermostat thats in it ,when ambient temp. goes up so will your engine temp..sounds like it might need more cooling capacity[thicker radiator]
Seneca SS is offline
post #6 of 13 (permalink) Old Apr 24th, 07, 10:16 PM
I can't get my 327 in my Nova to go over 190 so far. 4 core Brass Radiator, Factory Shroud, 17" FlexaLite 5717 fixed fan blade and Flexalite 5555 Thermal Fan Clutch
2/3rd Distilled Water, 1/3rd Supertech AntiFreeze, 9.5:1 compression
and
Brian Lewis is offline
post #7 of 13 (permalink) Old May 3rd, 07, 11:47 AM
Is the water temp sending unit in the head or is it in the intake manifold? A reading from the head should run higher than a reading from the intake, especially at freeway speeds. Anyone else agree?
Chevy Chase is offline
post #8 of 13 (permalink) Old May 3rd, 07, 05:39 PM
JohnZ's Avatar
Have you verified the gauge reading against an I.R. gun shot of the radiator hose just above the thermostat housing so you know what the gauge is really telling you? You may not have an issue at all.
JohnZ
CRG
JohnZ is offline
post #9 of 13 (permalink) Old May 3rd, 07, 05:41 PM
JohnZ's Avatar
Nope - there's only about 8" of coolant travel from the head-mounted sender location to the intake-mounted sender location; if there was 2* of difference I'd be surprised.
JohnZ
CRG
JohnZ is offline
post #10 of 13 (permalink) Old May 4th, 07, 03:31 AM
Could the thinner cylinder wall be conducting more combustion heat faster into the coolant?
Coolant in a closed system under 15 PSI will boil at 267*F, 3* per 1 PSI.
Everett#2390 is online now
post #11 of 13 (permalink) Old May 9th, 07, 05:01 PM
185 to 195 would be normal
you may have other issues going on ...not enough cooling from the rad may be one .
a good rad good flow and good cfm are keys to cooling .
here to help with cooling solutions
Alumitech Reproductions
517-404-6262
alumitech is offline
post #12 of 13 (permalink) Old May 9th, 07, 05:24 PM
keypilot's Avatar
electronic or manual gauge?
Don't stop now!!!
67 camaro driver
383 10:1
Horsepower:
515 @ 5,500 rpm
Torque:
499 lb-ft @ 4,800 rpm
keypilot is offline
post #13 of 13 (permalink) Old May 10th, 07, 03:52 AM Thread Starter
thanx - all set, I replaced the radiator (went with the summit aluminum) now stays at 180f all day long
TSTONE is offline
what temp should i run? guccieng Heating & Cooling 5 Feb 10th, 07 02:06 AM
69 console temp gauge not working garyj Electrical & Wiring 3 Jul 22nd, 06 12:32 AM
Will not crank at operating temp? fasthotrodtodd Troubleshooting 6 Jul 1st, 06 11:45 AM
Correct A.I.R. Smog Tubes? Littletommy Engine 2 Apr 16th, 05 05:06 AM
numbers correct 327/275 bluesdog Restoration Corner 0 Feb 1st, 05 03:46 PM
