BB conversion, heater core problem... - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 23rd, 07, 11:21 AM Thread Starter
Brad
My car came stock with a small block V8 therefore has the small block heater core cover and heater core. The small block was replaced by the previous owner with a 396 therefore the heater core pipes are directly behind the passenger side valve cover. If I buy a BB cover and heater core, will they fit without any other modification?
_____________________________________________
1969 Camaro SS X55, 383 stroker, 12-Bolt, Hotchkis Suspension, Torq-Thrust II 18" Wheels
Gignem is offline
post #2 of 10 (permalink) Old Apr 23rd, 07, 12:37 PM
Smile Re: BB conversion, heater core problem...
Do a search on this... You can flip your core over and put new holes in your cover and plug the old holes. You should even find pictures here. Here it is for you :
https://www.camaros.net/forums/showth...ore#post742760
Also note that this only works on non-ac cars.
TJS69 is offline
post #3 of 10 (permalink) Old Apr 23rd, 07, 12:47 PM
Here ya go:
It's easy. Use the same cover, but drill a hole in it for the new core. Then get the BB heater core adapter plate from one of the restoration parts places. Heres a thread with a pic of the adapter plate. To cover the hole where the SB core exited, you use a piece of closed cell foam. You can get it at the resto places or at a hobby store like Michael's probably. Also, you need to 'modify' the clip that holds the core in place... I don't remember exactly how, but it was pretty self-explanatory (if I figured it out )
https://www.camaros.net/forums/showthread.php?t=102938
His and Hers Marina blue 67's
67FamilyFun is offline
post #4 of 10 (permalink) Old Apr 23rd, 07, 12:50 PM
I just noticed your screen name and it appears you may be an Aggie. You probably will need to find some more threads with pictures. :P Let me know if you need help with that...Go Horns!
post #5 of 10 (permalink) Old Apr 23rd, 07, 03:23 PM Thread Starter
Brad
OUCH!! That hurts, but funny nonetheless. I wouldn't expect anything less from a t-sip. Thanks for the help. I haven't even looked at how the heater core is mounted. Do I remove it from inside the car or from the hood compartment. Also, what all, if anything do I need to remove in order to get the cover off?
Gignem is offline
post #6 of 10 (permalink) Old Apr 23rd, 07, 04:19 PM
It's sorta a PITA. Here's a thread with pretty good instructions and tips.
https://www.camaros.net/forums/showthread.php?t=49308
There is one nut that is under the fender where you can't hardly get your hand too. Some folks remove the fender...some the whole front clip...some have cut a hole in the inner wheel well...most find a way to get to the nut. I removed the front clip...then I sorta ended up with coilovers, bbc, new tranny, etc...beware the snowball.
post #7 of 10 (permalink) Old Apr 23rd, 07, 07:17 PM Thread Starter
Brad
Oh yeah, the "snowball effect". Just what my wife's afraid of. I'll take that into consideration because if I pull the fender, I might as well pull the clip, and if I pull the clip, I might as well upgrade the suspension, and if I upgrade the suspension, I might as well... well, you get the picture. O.K. so maybe I put this project off until October, because I don't need it anytime soon and it will be a great excuse to make a long Christmas list. Thanks for the help.
Gignem is offline
post #8 of 10 (permalink) Old Apr 24th, 07, 09:32 AM
Codi's Avatar
Sounds like your plan of action Scott.
Daddy's Hot Rod.
Codi is offline
post #9 of 10 (permalink) Old Apr 24th, 07, 09:57 AM
Yep...Of course, none of that snowball nonsense would have happened to my car if you hadn't had said something to the effect of, "You really ought to convert over to a BBC heater core as long as you're replacing it..." to me that day at your house...And then gone on and told me how to do the conversion...
post #10 of 10 (permalink) Old Apr 25th, 07, 09:51 AM
Codi's Avatar
OK! I'm sorry. Next time I see you, we'll pull the BB and put a 307 in it. It will be slower to the ice cream stand and not as much fun.
Daddy's Hot Rod.
Codi is offline
Heater core installation Dynawolf Heating & Cooling 7 Mar 1st, 06 05:24 PM
5 year Antifreeze and its effects on heater core tz1238 Heating & Cooling 14 Sep 27th, 05 10:35 AM
HEATER CORE QUESTION neverswt Tech 2000 1 May 22nd, 01 10:21 AM
Heater core questions Eric68 Tech 2000 8 Mar 20th, 01 11:42 AM
69 heater core... MY FIRST 69 Tech 2000 6 Feb 19th, 00 12:57 PM
