89 iroc z cooling issue - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 26th, 07, 04:20 PM Thread Starter
I have an 89 Iroc 5.7 tpi. The cooloing fans are not coming on. It doesn't run when the a/c is on or when the temp rises above 240. I have researched the archives and am wondering how I decide if it's the relay, the switch, or the ecm? I know where the relay is, where is the cooling switch and the ecm.
I disconnected the relay and ran a jumper across the the harness for the fan and the fan came on (ignition key was on and temp was about 240). Is this a sure fire indicator that the relay is bad?
Thanks for any help,
Frank
FrankF199 is offline
post #2 of 10 (permalink) Old Apr 26th, 07, 05:29 PM
Re: 89 iroc z cooling issue
there is always power going to the relays. i think you got 2 relays 1 for coolant temp and another for a/c. a ground completes the circuit for the fan to come on. if 1 fan coolant turns it slowly ac makes it faster. if 2 fans 1 comes on with coolant temp other comes on with a/c.
jaguareats is offline
post #3 of 10 (permalink) Old Apr 26th, 07, 06:14 PM Thread Starter
OK thanks, that makes sense cuz when I jumped the relay, the passenger side fan came on only. So now it sounds like the relay must be okay. Where can I find the cooling fan switch and how can I test it?
Thanks,
Frank
post #4 of 10 (permalink) Old Apr 27th, 07, 03:23 PM
i think it goes into the intake manifold somewhere.
once you do find it, you can pull the wire off and ground it to see if that makes the fan turn on. if the fan turns on, then the switch is bad. you can get a colder switch at NAPA if you want the fans to come on earlier- but they will have to break out the big book with pictures of all the temp switches and their temp ratings to find one that will work for you.
you don't plan sincerity.
novaderrik is offline
post #5 of 10 (permalink) Old Apr 27th, 07, 03:27 PM
the sensor is right by the thermostat housing 1 is for guage and another for fan to come on. if you disconnect it the fan should come on. if it does than relay is ok. if it dont the ecm is no good. the ecm grounds the relay and than fan comes on.
post #6 of 10 (permalink) Old Apr 28th, 07, 04:43 PM Thread Starter
OK, guys thanks, I pulled the connection from the sensor. Started the engine and let the coolant temerature come up to about 130 on the guage. I then shut the engine off and turned the ignition key on. I then grounded the sensor and the fans DID NOT come on. (BTW, there is only one relay for both fans)
Am I to assume this means the ECM module is bad?
Thank you for all your help, the car is my sons and I'm trying to save him some money by fixing this for him instead of takeing it to the dealership.
Thanks again,
Frank
post #7 of 10 (permalink) Old Apr 28th, 07, 06:12 PM
i wouldnt call the ecm bad without testing the harness, and running a data stream from the ecm through a scanner...i`d call the relay bad before the ecm...how did you test the relay???
kustomwerker is offline
post #8 of 10 (permalink) Old Apr 29th, 07, 06:32 PM Thread Starter
i pulled the connector and ran a jumper wire across the connector, when i did this the fan came on. I assumed the relay was bad but everyone else is saying it's the ecm.
Thanks,
Frank
post #9 of 10 (permalink) Old Apr 30th, 07, 06:10 PM
Mitch
Lost in the 60's's Avatar
Those fans are notorious for problems. My 88 is wired to a switch on the dash because the harness plug at the fans had melted in the past. There is another site dealing mostly in 3rd and 4th gen F bodies that has a lot of info on troubleshooting and repairing the fans on them. It's www.thirdgen.org
...38 Chev coupe, street rod
...54 Chev 210 coupe
...62 Impala SS, driver/project
...67 Camaro, ss/rs LA built driver/project
...66 Chevelle SS, Atlanta built 138 driver/project
...69 C10, cab and clip may end up on the '89 rollback
...70 Chevelle SS, Canadian documented Z25 project
Lost in the 60's is offline
post #10 of 10 (permalink) Old Apr 30th, 07, 07:23 PM
start with the relay...it`s easy...if you absolutely cant get it working, order an electric fan thermostat kit from summit or jegs and be done with it...they`re about 40 bux, and they have a bulb that goes inbetween the cores of the rad...then YOU set the temp that they come on...your car wont run hot anymore...
HELP!! Can't figure out this cooling issue Luke805 Heating & Cooling 4 Mar 21st, 05 03:11 AM
'97 Cooling Issue SRP44 Heating & Cooling 2 Apr 10th, 04 04:10 PM
Cooling Issue? bretcopsey Engine 3 Jan 21st, 03 01:51 AM
Reasons to keep my Iroc? Timmys88Z Tech 2002 8 Jan 28th, 02 07:32 PM
