Does size matter? - Team Camaro Tech
post #1 of 5 (permalink) Old May 2nd, 07, 10:45 AM Thread Starter
Does size matter?
I have my grille out of my 69 to fix my annoying squeak. I know I need to put a trans cooler in the car & it would be easier w/ the grille out. I am told bigger is better. The cut out for the radiator in the rad support is 22" wide from the bottom end. The widest cooler I saw was 21". I want to bolt it to the rad support not putting tie wraps thru my be cool radiator or butchering anything. Can anyone suggest something. I really want an aluminum color to match the radiator. Specs on my car are in the sig. Thanks. As always. Brian
1969 original SS in family since 1971.350/330 crate w/ comp 270 roller cam,2004R,355 12 Bolt posi,P/S P/FTD Brakes P/W P/TOP Orig A/C car but removed.
Car nut is offline
post #2 of 5 (permalink) Old May 2nd, 07, 12:57 PM
Re: Does size matter?
I don't think you'd be able to over cool the tranny.... I'd go big, but 21" sounds like it's for an RV.
21" x ??" ??
68 Camaro~LSx ~all motor
post #3 of 5 (permalink) Old May 2nd, 07, 01:11 PM
DjD
DjD's Avatar
The idea bigger is better isn't always what's best. You don't want to over cool your transmission. A lot of trans shops will plum the trans to the external cooler and then to the tank in the rad to insure what goes back to the trans isn't too cool.
The other issue is throwing a hugh trans cooler in front of your rad core may cause air flow restriction through teh rad core and cause over heating.
If your trans is new, talk to the builder about the trans cooler and follow his advice. He's the one that's going to be backing the trans if there is a problem.
...Dennis
DjD is offline
post #4 of 5 (permalink) Old May 2nd, 07, 01:57 PM
Steps
I have mine mounted at angle, going from the bottom of the radiator, down towards and nearly touching the the front of the chassis...
Oginally had it tmp behind the grill, but this , as mentioned above, caused to engine run a little hotter.
2 brackets, 5mmx 3mm one end bolted thru the bottom radiator support, with a bend, to get the angle of the cooler right, and cooler mounted to these with special cooler mounting bolts with large sponge type pads.
Steptoe is offline
post #5 of 5 (permalink) Old May 3rd, 07, 05:18 PM Thread Starter
I am ready to flip because I typed my entire reply and went to post the link and the reply puff dissapeared. Here I go again.
You guys are correct as usuall. Thats why this board is so great. I took Dennis's advice and called Art Carr @ Cpt transmitions where I bought it.He said bigger is better but I don't have to go 22". I just wanted to mount it to both ends of the rad support @ the bottom. He did say to get the plate type not tube & fin. I would still like to mount it to the bottom rail of the rad support. The Earl part in the link is perf but I hope I can buy A real mounting kit not that baggie tie strap deal. With the cooler low in front of the radiator it should get air sucked in from the dual 11" electric fans I am installing and some flow from the grill when moving wothout covering the entire radiator. Is this the way to go. Thanks so much. Brian.
EAR-41608ERL
Car nut is offline
what size steering wheel is best? guccieng Interiors 2 Feb 3rd, 07 12:41 PM
need to know tire size on standard 15x7 rims jcautoresto Wheels & Tires 2 Feb 2nd, 07 06:00 PM
Conveter size Toad Transmission & Driveline 2 Mar 16th, 04 06:20 AM
who knows how to size the head of a bolt when its measured in thread size cottonpicker14 Tech 2003 7 Jan 22nd, 03 11:10 AM
