clear coat an aluminum radiator? - Team Camaro Tech
post #1 of 5 (permalink) Old May 6th, 07, 08:01 AM Thread Starter
anyone tried this?
i was thinking of trying krylon spray triple crystal glaze #0500 after brushing the surface with a wire wheel. think it would peel, color, or detract from the cooling abilities of the aluminum?
maybe clear engine enamel?
maybe i should post this in paint, but i felt this was more about heat transferrence than paint.
all opinions welcome!
Eric B
86 camaro,383,topline vortecs,scat crank,wiseco forged 9.5:1,6"scat rods,comp xs282s,performer rpm,750 proform vac sec,msd in cap, hooker coated 1 5/8"headers,3"flowmaster,700r4,2800 stall,3.42 10 bolt posi,hotchkiss lca's,aje tube k member & a-arms
SLEEPER 86 is offline
post #2 of 5 (permalink) Old May 6th, 07, 10:09 AM
Jeff
Re: clear coat an aluminum radiator?
It won't cool properly.
Use a special type radiator paint - only.
Pacecarjeff is offline
post #3 of 5 (permalink) Old May 6th, 07, 02:00 PM
Steps
Also The clear will eventually 'yellow' , and with Al having a high expansion, over time cracking/peeling is very likely..
Then If /when these happen, the job of stripping, re polishing is not one I would take pleasure in doing.
Steptoe is offline
post #4 of 5 (permalink) Old May 6th, 07, 04:21 PM
Yep, don't "paint" the radiator, as said, it will retain heat.
I suggest using Alcoa protectant, its the third step of their alum wheel polishing/protectant method. It aprays on, then you rinse it off with water and dry with chamois or air gun. lasts for about 6 months, at least on their wheels.
post #5 of 5 (permalink) Old May 7th, 07, 04:10 AM Thread Starter
thank's for the tips guys!
Eric B
Aluminum radiator help please! camsdad Heating & Cooling 2 Mar 17th, 07 01:03 AM
Aluminum radiator choices.... wizard67 Heating & Cooling 15 Jan 31st, 05 08:39 PM
Aluminum heads vs. Cast Iron Heads peter19u Performance 67 Jul 15th, 03 02:16 PM
Aluminum radiator questions cody Performance 10 Aug 15th, 02 05:06 PM
Martin Senour Microlite & Evercoat Z-grip...compatible? 1968camaro123 Body Shop 3 Feb 17th, 02 11:18 AM
