flex-a-lite - Team Camaro Tech
post #1 of 2 (permalink) Old May 6th, 07, 03:25 PM Thread Starter
flex-a-lite
anyone have any experiences / thoughts with the flex-a-fit aluminum radiators? check out the link if you have not looked at one of these before.
http://www.flex-a-lite.com/auto/html..._radiator.html
one of the biggest complainants that i see with folks is the ability to bolt up an electric fan with a clean look. this has a pretty slick mounting system. the 52000l looks like a good fit and i think it would have no problem keeping a big block cool (with the right fan). the 52180l has a good size fan attached. yes this does add up in $$$ but the price is comparable to other aluminum/electric fan set ups.
Clean 67 - 600hp / 579ft lb, 502
St Petersburg, FL
mccomas is offline
post #2 of 2 (permalink) Old May 9th, 07, 04:44 PM
Re: flex-a-lite
If your rumming a manual trans this may be ok as they have adjustable brackets to mount to the core support and for the fan ... but wont work with auto trans ..no trans cooler built in .
check out this link
https://secure.wf-api.com/www.chevel...2oQlLR&sm=8856
DON
here to help with cooling solutions
Alumitech Reproductions
517-404-6262
alumitech is offline
whats the best flex fan wheezer Heating & Cooling 15 Nov 3rd, 06 06:03 AM
Main rear brake flex hose Meanchicken Brakes, Suspension & Steering 7 Sep 6th, 06 07:25 PM
Front Subframe/jacking question (frame flex) Brackneyc Camaro Tech 6 Mar 21st, 06 09:08 PM
04 Suburban E85 Flex Fuel - Methanol? kz1000ltd Bench Racing 16 Jan 13th, 06 11:45 AM
Which Flex Fan? racerboy3v Engine 4 Aug 12th, 01 07:37 PM
