sensor location??? - Team Camaro Tech
post #1 of 4 (permalink) Old May 10th, 07, 07:11 PM Thread Starter
Garry
sensor location???
Ok guys.. here's my problem.. I installed a ZZ502 in my 69 camaro and I am going to install a dual fan setup on it.. My problem is this..... There are only two spots on my intake to get to a water jacket.. one is for my heater hose and the other I have my temperature gauge sensor installed in it. Where else is there to install the sensor for my electric fans? It has to go in a water jacket somewhere.. Do I need to move my sensor for my temperature gauge? If so.. where??? Thanks guys
Garry
1969 LM1 Convertible Camaro
The restoration is ON!!
Musclecar is offline
post #2 of 4 (permalink) Old May 10th, 07, 09:32 PM
Re: sensor location???
isn't there a hole in the head somewhere?
you don't plan sincerity.
novaderrik is offline
post #3 of 4 (permalink) Old May 10th, 07, 10:27 PM
Tony
Ghostbuster's Avatar
Cool Re: sensor location???
Some manifolds have 2,3 or 4 ports up front..
I've heard of people drilling and tapping their manifolds.
I've also seen the gooseneck with built-in sensor port.
You can also get the heater hose fitting, with a sensor hole in the side.
Check out Jegs and Summit online..
Ghostbuster is offline
post #4 of 4 (permalink) Old May 10th, 07, 11:01 PM
The one I got from flex-a-lite tucked into the upper radiator hose on the radiator side,not the block side?!
fearsomfoe is offline
