overheating - Team Camaro Tech
post #1 of 6 (permalink) Old May 11th, 07, 04:25 PM Thread Starter
Rex
overheating
I have a friend that has a 93 buick skylark custom with the 3.3 litre engine. overheats and it acts like a themostat. It is not, tried three different brands. Not the water pump either, water is flowing across the radiator. There is a 50 degree temp swing from upper hose to lower hose....water is flowing through the motor. Any ideas?
69 x-11..LS1, 420.88 horse to the tires,750 Holley Ultra DP, Torquer V2, darksides headers, PRC heads, 10.8:1 compression, forged bottom end, 5 speed. 2008 King Ranch F150 4x4.
trex70 is offline
post #2 of 6 (permalink) Old May 12th, 07, 12:58 PM
Steps
Re: overheating
Do a HC test on the radiator for head gasket
If thats -ve
Pull the radiator out and get the header pulled and radiator manually cleaned
What is the bet the radiator has never had regular service...
This is assuming timing, and tuning is all correct.
Steptoe is offline
post #3 of 6 (permalink) Old May 12th, 07, 02:11 PM
Fred
Re: overheating
What's telling you that it's overheating? Seems like a 50* drop should take care of any cooling needs.
A couple of years ago after climbing a grade I looked at the temp guage of my truck. It was pegged over to 'hot'. I immediately went into survival mode. Turned off the A/C and turned on the heater, stuff like that, and stopped at the next station. Coasted to the water hose, leaped out of the cab, popped the hood and,,,,,,,,,,,,,, stopped. Normal heat radiated from the engine. It's the guage. To hell with it. Bought a new Duramax!
128.79mph 1.428 60'
Fred Ficarra is offline
post #4 of 6 (permalink) Old May 12th, 07, 07:54 PM
Tim
77wolf10.85's Avatar
Re: overheating
I'm with Fred, to hell with it buy a new Duramax! I did!
If you know you have a 50* drop across the radiator you must be using a temp gun. What is the engine temp? and in/out of radiator?
Tim Smith
77wolf10.85 is offline
post #5 of 6 (permalink) Old May 12th, 07, 08:56 PM
Re: overheating
how hot does it get?
if it's under about 230 degrees, it's normal for the car. if it's boiling over at that temp, put a new radiator cap on it.
you don't plan sincerity.
novaderrik is offline
post #6 of 6 (permalink) Old May 12th, 07, 10:09 PM
Steps
Re: overheating
If u have n over heat issue..always do the basics
Sure the gauge maybe out, but replacing that knowing the basics are ok is a good safe feeling....
A quick check u dont have blocked cores...
Start the car up cold
Then carefully feel the radiator with open hand, slowly..
A good stock radiator heats up reasonably even.....
2 blocked or restricted cores can be felt easly
1 harder, and 1 restricted will warm up slow 1 end
At 1st u may find y think there is maybe one...
recheck on a couple other cold starts....been sitting 3 or 4 hrs even in a hot day.
The most likely blockage/ restrictions are in the bottom 1/4 of the radiator.
I have done this many times over the yrs and been there when the headers are pulled off the radiator, and seen where and what comes out.
radiators that at have become too blocked and radiators that are being checked out as routine for new heads/engine rebuilds...old new serviced and abused.
Just because a radiator is flow checked...That doesnt mean a radiator is working ar FULL effiency....Chevy 1st gen ragiators are way over built
Steptoe is offline
Bummer...STILL Overheating.....HELP ! markr Heating & Cooling 37 Oct 24th, 06 11:07 AM
2001 V6 overheating scoobydoo Fourth Generation 1 Oct 19th, 06 05:03 PM
My car is overheating..AGAIN! FRIJOLITO Engine 7 Oct 5th, 06 06:23 PM
86 Z28 Overheating Magicmile24 Heating & Cooling 2 Jun 12th, 05 06:10 AM
also overheating angelglo Engine 4 Apr 21st, 04 09:00 AM
