Fan Shroud - Team Camaro Tech
post #1 of 6 (permalink) Old May 13th, 07, 03:45 PM Thread Starter
Banned
Alan
98blackburb's Avatar
Fan Shroud
I have a late model 350 motor with electric fan, I want to convert back to shroud/fan...motor has serpentine system with offset idler pulley....will a regular clutch fan work or do I need a flex fan? Anyone have this setup?
98blackburb is offline
post #2 of 6 (permalink) Old May 13th, 07, 04:10 PM
Re: Fan Shroud
more info and mostly what year camaro.
jaguareats is offline
post #3 of 6 (permalink) Old May 13th, 07, 04:25 PM
Ron
Re: Fan Shroud
I just installed a GM 330-350 turn key engine in my 1968 Camaro. The engine has the serpintine system and I used the standard 1968 Camaro shroud and installed a 18 1/4" reverse drive flex fan. This works very good. Please note you will need to use a reverse drive fan with the reverse drive water pump used with the seprintime system.
Viking11 is offline
post #4 of 6 (permalink) Old May 13th, 07, 04:32 PM Thread Starter
Banned
Alan
Re: Fan Shroud
Sorry Guys,got ahead of myself....1969 Camaro SS......Thanks for the help..........where did you get it from Viking?? Thanks
post #5 of 6 (permalink) Old May 14th, 07, 06:14 PM Thread Starter
Banned
Alan
Re: Fan Shroud
Viking ,did you use a spacer with this setup??? Thanks again.......Alan
post #6 of 6 (permalink) Old May 14th, 07, 06:49 PM
Re: Fan Shroud
The best flex fans are Derale, either as 17 or an 18". I use a 17 and she cools perfectly. They make a reverse rotation as well. You will need a spacer, probably 2". Measure from the back of the shroud to the front of the water pump pulley, add an inch to an inch and a half, that's the spacer you need.
Fan shroud fearsomfoe Heating & Cooling 10 May 11th, 07 02:27 PM
Fan Shroud help MrDanB Heating & Cooling 4 Jun 4th, 06 08:29 AM
Fan shroud rsbecool Engine 3 May 12th, 06 06:50 PM
fan shroud birdman3r Camaro Tech 4 May 6th, 05 10:10 AM
