cooling fan question - Team Camaro Tech
post #1 of 8 (permalink) Old May 15th, 07, 02:14 AM Thread Starter
Marc
This might be a stupid question, but would it make a difference while driving in town to have a cooling fan on the intercooler? My motor doesn't have a problem running hot at highway speeds or on the track, just the stop and go driving, 40 mph and under.
Marc
67 Camaro, 454, TH400, 9" 4.11's
camaro man is offline
post #2 of 8 (permalink) Old May 15th, 07, 06:38 AM
Re: cooling fan question
The best bet would be to address the cooling problem in the cooling system proper. At no or low boost you aren't heating the intercooler up very much.
onovakind67 is offline
post #3 of 8 (permalink) Old May 16th, 07, 01:40 PM
Fred
Beautiful car!!!
But I think I found your problem,,,,,,, you need a REAL fan and SHROUD. Especially at your power level.
128.79mph 1.428 60'
Fred Ficarra is offline
post #4 of 8 (permalink) Old May 17th, 07, 06:11 AM Thread Starter
Marc
I installed a Flex-A-Lite Black Magic Extreme FLX-180 fan with a shroud about 3 weeks ago. It pulls 3300 cfm. I'm thinking that the size of the intercooler is interfering with the air flow through the radiator, but I could be wrong.
Marc
post #5 of 8 (permalink) Old May 17th, 07, 09:35 AM
Fred
Marc, I found another clue in your original post. You say the car cools fine at highway speed but not slowly in traffic. That means air is moving through all your coolers just fine. The fan you have doesn't have enough balls. Oops, can I say that?
128.79mph 1.428 60'
post #6 of 8 (permalink) Old May 18th, 07, 04:44 PM Thread Starter
Marc
Fred, Do you know of any fans with a shroud that will fit that pulls more than 3300 CFM? My radiator is 22.5" by 18". The Flex-A-Lite Black Magic Extreme FLX-180 fan is a 16" fan.
Marc
post #7 of 8 (permalink) Old May 20th, 07, 01:24 AM
16" electric fans are typically around 2200cfm.
A 17~18" 7 blade OE clutch fan will move considerably more air, and only when it's needed. Of course they're RPM dependant, which is usually when you need the air anyway.
OE shroud should work unless your radiator is something unusual..
Many say you don't need a fan at speed, yet in my daily driver, I can feel the clutch lock up at 60mph and watch the temp gauge's needle drop as a result.
BlackoutSteve is offline
post #8 of 8 (permalink) Old May 21st, 07, 02:38 PM
Fred
I don't have a clue Marc. You know, these cooling systems were engineered buy people who smile in their sleep. Like Steve said, production stuff is hard to beat.
Did you see that fan-test in Hotrod about 10 years ago? Seven blade hi-po fans (OEM) with a thermal clutch cooled the best and used the least horsepower.
128.79mph 1.428 60'
68 RS cooling fan configuation Mikes68rs Heating & Cooling 2 Mar 11th, 07 07:26 PM
Flex fan being trashed/why not weld a clutch fan? wheezer Heating & Cooling 4 Jul 15th, 06 05:06 AM
95' electric cooling fan help bound2b5150 Electrical & Wiring 1 May 26th, 06 11:42 AM
68 Z28 fan blade dimensions bwhitfield Heating & Cooling 2 Apr 4th, 06 07:50 AM
Clutch Fan Question? fdny37 Restoration Corner 6 Nov 17th, 05 06:54 PM
