Freon amount - Team Camaro Tech
post #1 of 6 (permalink) Old May 21st, 07, 08:41 AM Thread Starter
Freon amount
Could anyone give an amount of freon -12 for an evacuated AC system for a 69 camaro. Replacing my condensor and hoses and was needing to the exact amount to put back in i Thanks, Wayne
wayne payne is offline
post #2 of 6 (permalink) Old May 21st, 07, 11:11 AM
Rex
Re: Freon amount
you probably should take it to a shop and have it evaced and recharged, that way you know exactly how much is in, I would have a dye introduced as well, in case you develop a leak...have you thought about converting to r134a? It will be cheaper in the long run.....
69 x-11..LS1, 420.88 horse to the tires,750 Holley Ultra DP, Torquer V2, darksides headers, PRC heads, 10.8:1 compression, forged bottom end, 5 speed. 2008 King Ranch F150 4x4.
trex70 is offline
post #3 of 6 (permalink) Old May 24th, 07, 11:14 PM
parkbrau's Avatar
Re: Freon amount
Wayne, 3 3/4 Lbs. R-12.
parkbrau is offline
post #4 of 6 (permalink) Old May 25th, 07, 06:09 AM
Re: Freon amount
With either gas use, get the oil in the compressor first. I believe it was 4 oz for compressor. Oil for 134 is differant, called PAG type oil I believe.
With all the new parts , you could go to 134, Your POA valve may have to be modified or replaced to work with this. If you have the evactuator pump and gauges, you can do this at home with 134. It almost requires an act of God to obtain R12. R12 is very high in cost.
Word of caution, don't go using anything like butane or propane or the blend gases.
TC # 349
zdld17 is offline
post #5 of 6 (permalink) Old May 25th, 07, 07:33 AM
Re: Freon amount
zdld17 is correct about Freon (R12).
R12 has not been produced in this country in about 10 years. Possibly longer. I spoke to one of my old bosses in the auto service industry and he said he hasn't been able to buy it since the start of this decade. Some people may sell it on the black market but he told me he's not about to go to jail over R-12. If I recall correctly production of Freon was halted by the clean air act. This act took effect on December 31, 1995 or January 1st 1996.
Most auto manufacturers started going with R134-A in 1993.The rest followed in 1994.
P.S. You know what I just did a search for you guys. Here is a good site I found http://www.r-12.com/
1) 1969 Camaro RS 396 TH 400, 12 bolt 3:73 sold 1994
2) 1984 Z28, 5.0 H.O. T-Tops, G92 3:73, sold 1994
3) 1988 5.7L IROC-Z, sold 1994
4) 1969 Camaro bought 2006, back on the road in 2010
post #6 of 6 (permalink) Old May 25th, 07, 08:20 AM
Farm Boy's Avatar
Re: Freon amount
If you are using R-12 evacuate the system first then fill it slowly until the sight glass is free of bubbles. When you no longer see any bubbles the system is full. All of these early systems have a sight glass on the high side. You will need 4 or 5 pounds of R-12. Only use this method if you are using R-12.
Farm Boy is offline
Proper amount of welds? makoshark Body Shop 3 Dec 28th, 06 10:54 AM
Classic Car Insurance........ jm69ss Camaro Tech 43 Jan 27th, 06 07:52 PM
Amount of vacuum, broken reservoir, brake booster utztech Brakes, Suspension & Steering 6 Aug 5th, 05 10:57 AM
Sandblaster sand amount? Steelie73 Body Shop 4 Apr 9th, 05 05:14 AM
Air Cond. convert to new freon, advice? click Tech 2002 23 May 17th, 02 01:49 PM
