electric fan blowing fuses - Team Camaro Tech
post #1 of 7 (permalink) Old May 21st, 07, 03:34 PM Thread Starter
Rusty
I have been having a problem with my electric fan blowing fuses. I installed this relay setup and it is still blowing fuses! (last setup had a relay no temp sensor)
http://store.summitracing.com/partde...5&autoview=sku
It only seems to happen when I racing or high stress on motor not cruising.
Next step I guess is to reaplace the fan. I am currently runnign an ac delco dual fan.
Would a stock alternator have any thing to do with it?DO i need a highr amp alt?
ANy suggestions?
gotsnappy is offline
post #2 of 7 (permalink) Old May 21st, 07, 03:41 PM
Jeff
Re: electric fan blowing fuses
When I first installed my fan I had it blowing in the wrong direction. pusher vs puller. I swapped the black and red and all was good.
Jeff
jeff_gates is offline
post #3 of 7 (permalink) Old May 21st, 07, 06:58 PM Thread Starter
Rusty
Jeff,
thanks for the input. My fan is pulling the right direction, it just keeps popping fuses
post #4 of 7 (permalink) Old May 21st, 07, 08:23 PM
Bob
Sounds like a bad ground. I had a 55 Chevy that always blew the fuses for the dash lights. As it turned out, the paint I applied to the dash was Imron (old style poly) I thought I had grounded the cluster well, but I was wrong. I'd try taking the area for the ground down to the metal.If there is paint or slag in the way at all, it could be enough to mess up the ground,causing the fuses to blow. An electric fan draws a fair amount of amps. The fact that you are using relays should have addressed it. The ground also has to be up to the task. Fuses blow because of too much resistance somewhere in the circuit. I've found that at least 80% of electrical problems on Chevies are as a result of poor grounds. Give it a whirl....might be what the doctor ordered. If its not the ground, the fan is probably bad as you said.
BelAirBob is offline
post #5 of 7 (permalink) Old May 21st, 07, 09:51 PM
Ron
What Alternator you running. I don't believe a 10SI is big enough. You will probably require a CS130. An Electric Fan can demand as much as 35 Amps upon start up and will shock the Electrical System with a 600 Volt Back EMF surge through the Relay Coil if not Diode Protected and will burn out transistors in your after Market CD Ignitions Components and even your Digital mp3 Player. You can put in a bigger fuse but you can probably get away with a smaller fuse if you have a bigger alternator.
This was my 70 1/2 Z28
Z15CAM is offline
post #6 of 7 (permalink) Old May 22nd, 07, 06:42 AM Thread Starter
Rusty
Okay guys thanks for the input. I will replace my ground wire and see what happens from there! If it still blows fuses I will check out the alt. I think it is just a stock alt nothing upgraded.
post #7 of 7 (permalink) Old May 22nd, 07, 02:34 PM
You might insert a shop ammeter in line with the new ground wire to see how much current is being drawn. Then fuse for 150%.
Electric fan causes high rpm miss? shift Performance 7 Oct 10th, 06 06:47 PM
Electric Fan theory questions 69 Rat Heating & Cooling 8 Oct 2nd, 06 07:29 PM
Alternator size and electric cooling fan Eric Kammerer Electrical & Wiring 6 Mar 7th, 06 03:17 PM
Taraus Electric Fan Sixty-Seven rs Heating & Cooling 8 Jul 8th, 05 09:57 PM
Mark VII Electric Fan bezo89 Heating & Cooling 4 Apr 9th, 05 07:22 PM
