Temp Gauge readings - Team Camaro Tech
post #1 of 12 (permalink) Old May 22nd, 07, 12:49 PM Thread Starter
Temp Gauge readings
Hi All,
I have just purchased an 86 IROC with a 383..
I have only had it a couple of days but notice that the temp gauge shoots up off the scale after about 5 mins or less of running.. It varies a lot between FSD and say 220F. It can drop from FSD way past 260 to maybe half way in about 10 seconds so it does indeed sound like faulty gauge or sender. I was wondering if this is a common fault and if anyone could recommend any reliable aftermarket gauges or senders?
I did do a search through the archives but could not find exactly what I was after?
DeK
pezza is offline
post #2 of 12 (permalink) Old May 22nd, 07, 05:26 PM
Larry
Re: Temp Gauge readings
if it reads that hot and you are not spewing water out of the overflow, chances are it's not hot and a sending unit problem. The experts say, if you are not losing water, it isn't overheated... Also if it's a thin casting 400 block that has been bored... you might call Houston... cause you have a probllem
Sometimes it's better to let someone think your an idiot, than to open your mouth and remove all doubt...
ls427ss is offline
post #3 of 12 (permalink) Old May 22nd, 07, 05:39 PM Thread Starter
Thanks for that, lets hope its just the sender unit then as the car is not losing water or steaming!
I will look to replace this..once I locate it!
Any recommendations for aftermarket equipment?
Cheers
Dek
pezza is offline
post #4 of 12 (permalink) Old May 22nd, 07, 06:24 PM
The sender will be scrwed into one of the heads, between the spark plugs, or more likely on the front of the intake, near the thermostat. It will have one wire attached to it.
From how it's behaving, I'd suspect a loose or damaged wire. Reading full scale is a sign of an open circuit, that would be loose, or partway broken.
For a quick peek at what the temp really is, take off the rad cap (with the motor cool) and put your wife's meat thermometer in it. Then start the engine and let her idle til she's warm and check the thermometer. Don't let your wife see you do this.
post #5 of 12 (permalink) Old May 23rd, 07, 12:16 AM Thread Starter
Thanks for the advice Jim I will have a quick peek today to see if I can find it.
I have already stolen a thermo from house to test I will let you know.
pezza is offline
post #6 of 12 (permalink) Old May 24th, 07, 04:14 PM Thread Starter
Hmm so I have changed the sender and .. no change I also realised that there was v lil water gushing out when I changed the sender so I filled rad up with water/coolant mix. But this still did not help
The needle still shoots up just over the red within a minute or so... and the car is very very unhappy esp at idle
Now, just before this, a few days ago i did notice the needle rising fairly rapidly and falling very quickly way beyond the time it would take the temp of water to change. Having changed sensor, this is much more gradual as expected but its still very hot past the scale.
Tonight I also notice my radiator cap is not working as overflow bottle was cool and not venting steam either so I will change that...
Both inlet and return 2-3inch pipes are warm/hot etc so water is being circulated. What else should I be checking?
- Rad fan and switch? (I have moroso engine fan I believe but not checked rad fan coming on)
- Thermostat???
Any other ideas?
Any info/ideas/help/suggestions would be very welcome..
DeK
pezza is offline
post #7 of 12 (permalink) Old May 24th, 07, 05:47 PM
and does the meat thermometer agree with your gauge?
We really need to know if we're fixing an overheating problem or a bad gauge reading problem.
edit: also, I'm not familiar with some of the physical details of those years, exactly where on the motor is the sending unit?
post #8 of 12 (permalink) Old May 25th, 07, 07:38 AM Thread Starter
Hi Jim,
Thanks fo ryour response...
The thermometer I brought with me to work to test did not work
I will try find a digital one at work to test with tho.
I will report back..
The engine, I believe is, the last of the 5.7s from the 2nd Gen Camaro's before the 88+ 5.7s reappeared.
The coolant sender is located as show in the red circle in the following pic
http://www.aquavibe.demon.co.uk/pub/enginebay.JPG
I also hardwired the fan from the rad this works but takes it power from a little box market Mr Gasket. One wire from this control box has a probe which is stuck into the rad.
Thanks for your help so far
Dek
pezza is offline
post #9 of 12 (permalink) Old May 25th, 07, 11:54 AM
Harley
wiskeesour's Avatar
stuck thermo or its upside down...
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #10 of 12 (permalink) Old May 25th, 07, 03:20 PM Thread Starter
Hi Jim
Managed to spend some time to check it out today and it seems gauge was correct in water temp.
Suspect Head Gaskets as being cause.. esp now as steam is coming out of oil breather . Explains where rad water was goin with no obvious leaks
I am hoping the job will not be too difficult compared to modern day blocks!
Any high performance Gasket manufacturers anyone can recommend?
Are Fel Pro a respected performance manufatcurer?
Thanks for any info anyone may have.
Dek
pezza is offline
post #11 of 12 (permalink) Old May 25th, 07, 04:51 PM
Bad news, but at least you know.
Does the oil look milky? That would confirm a problem.
post #12 of 12 (permalink) Old May 26th, 07, 02:03 PM Thread Starter
HI Jim,
Indeed the oil is looking milky now which is bad news..
So gaskets, head skim.. Not sure how much that is gonna cost
But it seems that accessibilty is much more straight forward than modern
performance cars...
Gaskets wise, I can see from the car's previous history the car had Fel pro 1010s then later fitted with 1094s.
pezza is offline
67 console temp gauge question Eighttrakz Electrical & Wiring 0 Mar 23rd, 06 03:39 PM
Temp. Gauge denis68 Electrical & Wiring 4 Jul 24th, 05 02:38 PM
Console Temp; Gauge clm69z28 Electrical & Wiring 4 Apr 22nd, 05 07:53 AM
Mechanical Temp Gauge Problem ? Rons68 Troubleshooting 11 Apr 10th, 02 10:25 AM
console temp gauge readings... mike brown Tech 2000 1 Feb 20th, 00 04:35 PM
