327 Running Hot Please Help - Team Camaro Tech
post #1 of 7 (permalink) Old May 28th, 07, 05:11 PM Thread Starter
I am at a total loss. My 327 which has about 300 miles on it has started running hot. Well, 210 - 230 which to me is too hot. It used to run at 185 at the most. I changed thermostat to a high flow 160 degree, new coolant, new radiator, etc.. Do you think my discount auto water pump went out or something. Please help. Thanks guys.
bdzee is offline
post #2 of 7 (permalink) Old May 28th, 07, 05:32 PM
Kevin
SixtyAte's Avatar
Re: 327 Running Hot Please Help
Are you sure you don't have an air pocket? Did you change the fan? I would pop the hose off the water inlet where the t-stat is and see if you put in on properly. While its out, fill the block with anti-freeze.
Test the t-stat in hot water to be sure it opens all the way. Put it back in and replace housing , hose , etc. Fill the system the rest of the way putting anti-freeze into the radiator .If that isn't the problem check that the fan is properly into the radiator shroud. About half in and half out is about right. See if any of this helped.
Kev
SixtyAte is offline
post #3 of 7 (permalink) Old May 29th, 07, 03:05 AM
Smile Re: 327 Running Hot Please Help
My 327 never runs hot. I put alotof of that to my stage 1 stewart water pump. Stewart water pumps are awesome ! I think I have seen summit is now carrying them, otherwise just order directly at
http://www.stewartcomponents.com/.
Please note: It won't cure the problem, if something else isn't right ! Make sure that your radiator cap is good !
TJS69 is offline
post #4 of 7 (permalink) Old May 29th, 07, 10:13 AM
Call me Funk
Send a message via AIM to CFunK
Why would the radiator cap cause overheating?
-Funk
CFunK is offline
post #5 of 7 (permalink) Old May 29th, 07, 10:29 AM
A radiator cap won't cause overheating. Venting to too low a pressure can cause boiling, if the coolant temp is hot enough to boil at that pressure.
... has started to run hot?
As in for most of those 300 miles it did not run hot, but reecently it does?
Check your timing.
Check your fan clutch if you run one.
Open the radiator (when cold) warm the engine, and observe that coolant starts flowing at the temp of the thermostat.
Compare the temp of the upper and lower rad hoses, lower should be notibeably cooler.
Observe inside the radiator while you jack the throttle a few times (motor hot enough to open the thermostat) level should drop, then rise more, then stabilize where it started out. There should be minimal if any bubbles. Bubbles would indicate a problem, head gaskets maybe or worse.
Does your oil look milky at all?
post #6 of 7 (permalink) Old May 29th, 07, 12:47 PM
As Jim stated a bad radiator cap will not cause it to overheat, it will affect the temperature at which your coolant boils. For example : straight water boils at 212*. If you now have this system under pressure, it will boil at a higher temperature. This is why you hear nascar racer's say the water temp. is 240* and this is fine. They are probably running a 22 lb. cap.
TJS69 is offline
post #7 of 7 (permalink) Old May 29th, 07, 02:36 PM
Steps
A bad radiator cap will cause over heating....
When the water biols, and it will in the block...it causes steam pockets, this causes cavitation in the pump and bad circulation...
Also loss of water .
Steptoe is offline
should this wire be hot to the touch? click Electrical & Wiring 5 May 6th, 07 07:50 PM
HOT horn relay king67rsss Electrical & Wiring 4 Apr 14th, 07 12:22 PM
305 running hot matsuuraman Engine 13 Mar 11th, 06 03:50 PM
Start my 327 after 16 years but! [email protected] Engine 0 Mar 4th, 06 03:04 PM
327 OR 350 mbonazzo Tech 2000 10 Apr 12th, 01 02:34 PM
