Engine Temperature - Should I be concerned? - Team Camaro Tech
post #1 of 15 (permalink) Old Jun 5th, 07, 09:23 AM Thread Starter
Erik
I have a 1969 Camaro with a 327 that I recently got back on the road. The motor was rebuilt a few years ago, but only has about 500 miles on it.
The engine runs great, but the past few weekends I have noticed that the engine temperature has been going up to 210 degrees after an hour or so of driving. This didn't happen in the Winter or Spring so it may be related to the warmer summer temperatures ( it's been around 90 degrees the last few weekends). When I drive it, it comes up to about 190 degrees and then stays there pretty steady for maybe a half hour or so. But as I continue driving with some stops, it eventually gets up to around 210. The first time it got to 210, the radiator overflowed some, but that hasn't happened since.
I have a 4 core radiator that I bought a few years ago that I think is fine. I just put a new water pump, 190 degree thermostat , heater core and hoses on. I also have a new 16 lb radiator cap.
My fan is about 2 inches outside of the shroud so I plan in extending it to see if that helps.
Should I be concerned? Any suggestions on what I might check?
Thanks.
69banana is offline
post #2 of 15 (permalink) Old Jun 5th, 07, 09:55 AM
click's Avatar
Re: Engine Temperature - Should I be concerned?
Your fan needs to be "inside" the shroud, thats probably your problem. The fan outside the shroud isnt pulling air like it should. I think it should be inside by about 1"-2" at most. Others with more cooling expertise will comment Im sure too.
click is offline
post #3 of 15 (permalink) Old Jun 5th, 07, 10:34 AM
I agree with everything Jim suggested, put the fan into the shroud.
If it still doesn't cool, my suggestion would be to get a larger crank pulley to overspeed the water pump and fan.
And Welcome to the Club! I see you're already into the East Coast humidity.
post #4 of 15 (permalink) Old Jun 5th, 07, 11:13 AM
madmax87's Avatar
I thought you always wanted the fan to be 1/2 in, 1/2 out of the shroud opening.
madmax87 is offline
post #5 of 15 (permalink) Old Jun 5th, 07, 11:18 AM
click's Avatar
Dennis the inner most part of the blade should be inside the back edge of the shroud about 1-2" so it pulls completely thru the radiator and not from around the outside of the shroud where the air is hotter.
click is offline
post #6 of 15 (permalink) Old Jun 5th, 07, 12:25 PM
madmax87's Avatar
madmax87 is offline
post #7 of 15 (permalink) Old Jun 5th, 07, 01:22 PM
Steps
Have a look at the CPUI fan or case fan on youe computer....
u will notive that the tips od the fan blades are as close to the shroud part as possible...
This stops air spillage off the ends of the blades, dramatically increasing fan effiency
To me your pic looks wrong...there seems to be a huge gap between the fan blade ends and the shround????...is that the right shroud/fan combo???
Also check the radiator cap is good and at least 13lb (std is 15lb I think)
Did u get the headers on the radiator removed and cores manually cleaned....
This should be std proceedure as is new oil pump/water pump is when rebuilding a new engine.
When one stops, there is no water moving, or very little, the heat of the engine heats the water faster hence the higher reading, then when one is moving again the temp drops...this is normal.
This is normal when the raditor is over full
Steptoe is offline
post #8 of 15 (permalink) Old Jun 5th, 07, 02:13 PM Thread Starter
Erik
Thanks!! I'll go ahead and extend the fan and see if it helps.
How hot should I expect the engine to get on hot days in stop and go traffic? If it never goes above 210, is that OK?
69banana is offline
post #9 of 15 (permalink) Old Jun 5th, 07, 02:14 PM
madmax87's Avatar
Steps, if your talking about the pic I posted, yes it is the correct shroud and radiator and 772 fan. The problem is I have an aftermarket upper shroud bracket and it does not let the shroud drop down far enough. The gap on the bottom of the shroud is the width of a finger. Still looking for a correct upper bracket.
madmax87 is offline
post #10 of 15 (permalink) Old Jun 5th, 07, 02:24 PM
you also may want recheck your timing
TSTONE is offline
post #11 of 15 (permalink) Old Jun 5th, 07, 05:47 PM
210 is nothing to worry about.
hell, with a 15lb cap, you really don't need to worry until it hits 230 or higher.
of course, it might detonate a bit at hotter temps, but that's the only really a problem if you don't tune for it.
get the proper fan- a good HD clutch fan- and get it into the shroud properly.
you don't plan sincerity.
novaderrik is offline
post #12 of 15 (permalink) Old Jun 5th, 07, 06:19 PM
Tim
77wolf10.85's Avatar
Does 69 have a fan clutch? If so is it kicking in?
If no fan clutch and you are more concerned with cooling than 100% original you might consider a performance fan or electric fan.
Tim Smith
77wolf10.85 is offline
post #13 of 15 (permalink) Old Jun 6th, 07, 01:32 AM Thread Starter
Erik
It has an aftermarket flex fan that I bought several years ago. Would I be better off getting a GM clutch fan from some place like Rick's Camaro or some other type of fan? I was just planning on extending the flex fan into the shroud for now.
69banana is offline
post #14 of 15 (permalink) Old Jun 6th, 07, 03:23 AM
Tim
Only comparison I have was on a 79 Chevy PU. Hands down flex fan pulled more air.
Hands down flex fan was a nuisance from a noise perspective.
I ended up with a clutch(took 3 to get a good one) and a home made shroud on a stock fan.
But it ran hotter above 100* ambient with the stock setup. I was after quiet on that truck.
The clutches were an expensive PITA. Last about a month, then you could tell they weren't kicking in any more.
Tim Smith
post #15 of 15 (permalink) Old Jun 6th, 07, 04:14 AM
I would do this for now and see what it does.
Be sure to check the bolt length, too short sux. Too long and rubs the pump casing. You want 100% thread engagement into the pump flange.
The additional thing you might do is to get some poster board & duct tape and blank off the space from the header to the radiator support. There is a thread and template for making this piece from alum floating around here somewhere. The second place to mask off is from the bottom of the valance panel to the radiator support. By doing this effort, you're providing a wind tunnel to prevent recycling the hot air.
Learning from revamping blower engine Tokyo Torquer Performance 11 Jan 24th, 07 12:44 PM
My 502 is driving me mad !! Engine Gurus', Please Help Me. paul1969 Performance 25 Dec 4th, 05 09:55 PM
1991 Camaro Engine Swap (88 IROC engine) Racing_Master Engine 7 Oct 20th, 05 03:22 AM
What engine is this inside of my 67 Camaro?? camaro_town Tag Team 3 Apr 23rd, 04 05:14 PM
