Heater Hose - Team Camaro Tech
post #1 of 13 (permalink) Old Jun 6th, 07, 08:49 AM Thread Starter
Bill
Heater Hose
Would there be any problem with me running the car with the manifold and water pump fittings plugged?
and just running the thermostat and upper/lower radiatior hoses?
BEECHFRONT is offline
post #2 of 13 (permalink) Old Jun 6th, 07, 09:49 AM
Re: Heater Hose
That would be fine.
TJS69 is offline
post #3 of 13 (permalink) Old Jun 6th, 07, 01:55 PM
madmax87's Avatar
Re: Heater Hose
No problem at all.
madmax87 is offline
post #4 of 13 (permalink) Old Jun 6th, 07, 02:46 PM Thread Starter
Bill
Post Re: Heater Hose
Thank's
post #5 of 13 (permalink) Old Jun 10th, 07, 10:53 PM
Mel
Re: Heater Hose
does anyone make a nipple that is actually a plug that still allows you to attach your heater hose to, effectively deactivating your heater but keeping the stock appearance?
Mel
69 Z28, DZ, M20, BU.
melav8r is offline
post #6 of 13 (permalink) Old Jun 11th, 07, 09:59 PM
Re: Heater Hose
Mel, Fill the intake manifold fitting and water pump fitting with J-B Weld, resin, or whatever, and put the hose back on it. Who will know but you.
Chevy Chase is offline
post #7 of 13 (permalink) Old Jun 12th, 07, 01:23 PM
Mel
Re: Heater Hose
You think it'll make a water tight seal in the nipple? I was thinking of having some solid ones made up from scratch, not sure if it is economically feasible, unless someone already makes them.
Mel
melav8r is offline
post #8 of 13 (permalink) Old Jun 12th, 07, 08:06 PM
Re: Heater Hose
JB Weld was used decades ago as a quick fix by farmers when a tractor developed a cracked block on the family farm. Clean the inside of the hose fitting with solvent. Tape the end. Pack with JB in several stages allowing to cure between stages. Install fittings. Run engine without the hoses to operating temp and check for leaks. It'll cost you less than $5.
post #9 of 13 (permalink) Old Jun 13th, 07, 06:02 PM
Mel
Re: Heater Hose
worth a try, thanks.
Mel
melav8r is offline
post #10 of 13 (permalink) Old Jun 22nd, 07, 02:16 AM
Mel
Re: Heater Hose
Actually figured out a better solution, bought a pair of heater hose fittings, 1/2" npt with 5/8" and 3/4" nipples, tapped the 5/8" fitting from the bottom side for a 1/4" npt plug and the 3/4" for a 3/8" npt plug. After installing the plugs, sealed tight as a drum. I used plugs with square heads which I ground down after install, guess I could've used the flush plugs which use an allen wrench to install. Regardless, worked pretty slick, now I can reinstall the heater hoses for the factory look and not worry about another heater core blowing up and spilling all over my carpet while keeping the heat out of the interior. Remember I'm in So-cal, don't need no stinkin heater!!
Mel
melav8r is offline
post #11 of 13 (permalink) Old Jun 29th, 07, 02:19 PM Thread Starter
Bill
Re: Heater Hose
another quick question,
if i plug up the manifold and waterpump should i drill a few holes in the thermostat?
post #12 of 13 (permalink) Old Jun 29th, 07, 02:37 PM
DjD
DjD's Avatar
Re: Heater Hose
Not necessary...
...Dennis
DjD is offline
post #13 of 13 (permalink) Old Jun 30th, 07, 07:19 AM Thread Starter
Bill
Re: Heater Hose
Thank's Dennis.
Bill
Heater hose shutoff italiano362 Heating & Cooling 5 Mar 5th, 07 07:45 PM
69 Z/28 Heater Hose Barbs dh302 Restoration Corner 7 Jan 11th, 06 12:41 PM
Heater hose routing Joe G Heating & Cooling 4 Apr 12th, 05 04:39 PM
Cannot access bottom heater hose connection!! Brian Lewis Heating & Cooling 4 Jul 10th, 03 10:02 AM
Heater Motor Hose? Joe G Tech 2000 8 Mar 17th, 01 06:05 PM
