Car will not stay cool? Need Help - Team Camaro Tech
post #1 of 33 (permalink) Old Jun 13th, 07, 04:37 PM Thread Starter
I have a 68 camaro with a 454 and i have a new griffin radiator and a low temp t-stat and even added a electirc fan. The car has a flex fan. And a very small shroud every time i look for a shroud everyone always shows me the same shroud. When the car is just idling it will reach up to 230 degrees? Anyone know what the problem is ? Also has a new water pump. Any help or opinions will be usfull since i have tried everything i can think of. Thanky you
Preluder77 is offline
post #2 of 33 (permalink) Old Jun 13th, 07, 04:48 PM
Harley
wiskeesour's Avatar
Re: Car will not stay cool? Need Help
is there any fluid mixing? oil, water, gas etc
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #3 of 33 (permalink) Old Jun 13th, 07, 05:58 PM
the only thing i can think to check if the head gasket has not blown is the direction the fan is blowing iv seen fans wired backwards the fan will be blowing the air in the wrong direction you can get block tester from napa to check for a blown head gasket.
obriens69 is offline
post #4 of 33 (permalink) Old Jun 13th, 07, 06:08 PM
DjD
DjD's Avatar
How does it do moving? Heating up when idling is usually not enough flow through the core and or not enough initial timing... A low temp stat won't help an over heating engine. If the cooling system can't bring the temp down below the stat rating it will never close.
...Dennis
DjD is offline
post #5 of 33 (permalink) Old Jun 13th, 07, 06:21 PM Thread Starter
Ok this is what i have been leaning towards is the flow through the core. My intital timing is set at 12 degrees sound right ? And the flow through the core could be at fault of the tiny shroud right?
post #6 of 33 (permalink) Old Jun 13th, 07, 06:43 PM
click's Avatar
Is your fan blade 'inside' the shroud 1 - 2 " ?? If not, the air isnt being pulled thru the radiator properly.
click is offline
post #7 of 33 (permalink) Old Jun 13th, 07, 06:51 PM Thread Starter
no it is not i cannot find anyone that has a shroud i can buy. I was thinking of going to the bone yard and getting a random one that looked good just to temp. modify it to see if that helps
What should this car be running at at idle ?
Jim i can email you a picture, What is our adress? Thanks
post #8 of 33 (permalink) Old Jun 13th, 07, 07:00 PM
click's Avatar
emails are in your name, right click on anyone's name and it has options for email or private message.
click is offline
post #9 of 33 (permalink) Old Jun 13th, 07, 07:17 PM Thread Starter
Ok jim i emailed you the pics tell me what you think.. Thanks for the help
post #10 of 33 (permalink) Old Jun 13th, 07, 07:42 PM
chris
did you check for air lock or air bubbles trapped in the system?
67 RS
68 Under Full Resto
cfauver is offline
post #11 of 33 (permalink) Old Jun 13th, 07, 07:54 PM Thread Starter
I did check for air in the system. I really think the shroud is the problem. The car will stay cool during driving. This is mainly an idle problem
post #12 of 33 (permalink) Old Jun 14th, 07, 02:48 AM
Berry
How bout an electric waterpump?
Its cheaper to be poor!
BERRY251 is offline
post #13 of 33 (permalink) Old Jun 14th, 07, 07:49 AM
click's Avatar
I got the pics but at that angle, its hard to see how far into the shroud the fan is. Im betting its a shroud issue and run a 180 degree stat too. Also, have you checked the accuracy of the guage? Shoot a thermal gun at the top of the radiator hose as it enters the engine, see how close to your guage reading that is.
click is offline
post #14 of 33 (permalink) Old Jun 14th, 07, 08:21 AM
DjD
DjD's Avatar
BB shrouds are shallow compared to a SB one. Is your electric fan a pusher or puller? Sounds like a pusher mounted on the outside of the rad core since you are talking about a shroud. If it is a pusher it's half the problem since it's blocking the core. Are you using a belt driven fan too? If so get rid of the electric in front of the core and see what happens.
...Dennis
DjD is offline
post #15 of 33 (permalink) Old Jun 14th, 07, 08:22 AM
Things I can think of for a hot running engine are--- Too lean , to rich, fan pushing air forward instead of pulling ( I SEEN IT), Timming, incorect head gaskets, blocked egr port (year specific), shroud, t-stat, radiator cloged.
How hot is it at cruz speed?
blue ss is offline
previous post: HELP ME FIND MY CAR PLEASE!! wiskeesour Tag Team 3 Nov 30th, 06 06:14 PM
Vintage muscle car reunited with original motor OverAnxious Bench Racing 3 Aug 29th, 06 04:58 AM
Outlaws At Atco 9/23-24 10k To Win, Car Show Too 351RAY Team Camaro Cruiz-Ins 1 Aug 21st, 06 07:02 PM
What is a 67 RS/SS worth? bazkoon Camaro Tech 14 Jun 21st, 06 08:58 PM
Cool Car! ChevyThunder Bench Racing 16 Sep 22nd, 05 06:47 PM
