BBC Radiator recommendations - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 14th, 07, 01:10 AM Thread Starter
Ed
BigBlock1969RS's Avatar
Lightbulb BBC Radiator recommendations
I have a 69 Camaro that I am swapping in a BBC into (should be around 500-550 hp), and I need to replace the stock radiator with something more beefy.
Any recommendations on good radiator manufacturers? What people think about:
Be-Cool
Griffin Radiator
Ron Davis
I have heard that Spal fans are the best. I was thinking of going with the Ron Davis radiator that is a direct fit for 67-69 Camaros (P/N 11-16CA67 with coolant recovery tank and dual 13" Spal fans)
http://www.rondavisradiators.com/radgallery.htm
BigBlock1969RS is offline
post #2 of 4 (permalink) Old Jun 14th, 07, 04:39 AM
Re: BBC Radiator recommendations
check out http://www.chevellecooling.com/ for Alumitech radiators.
I have one on my BBC. Looks original, cools great.
His and Hers Marina blue 67's
67FamilyFun is offline
post #3 of 4 (permalink) Old Jun 14th, 07, 04:42 AM
Oh, also I'm using stock (aftermarket) BBC shroud and 7-blade fan and clutch.
post #4 of 4 (permalink) Old Jun 14th, 07, 12:51 PM
This is the best there is.... http://www.fluidyne.com/pl_hpdomestics.html
Aluminum, three-row and will drop right in! About 25% more cooling capacity than any alum two-row. But, I will admit that Alumitech is a great product as well.
Steve "Jack'stands" Jack
HOTRODSRJ is offline
Cooling a short fill 468 BBC on the street ?? Eric68 Heating & Cooling 8 May 17th, 07 07:12 PM
Bbc Tall Block? bigsky4ever Tag Team 3 Mar 25th, 07 04:23 AM
BBC power steering question dubs68camaro Engine 0 Feb 26th, 07 05:40 PM
Need help with correct engine mounts (towers off frame) for '68 BBC dubs68camaro Engine 10 Jan 21st, 07 12:29 PM
engine swap kaaduba Engine 11 Dec 26th, 06 09:30 PM
