Summit Aluminum Radiator - Team Camaro Tech
post #1 of 32 (permalink) Old Jun 18th, 07, 10:54 AM Thread Starter
Bill
I have a few questions about the summit direct fit aluminum radiator,
is this really a direct fit? i did some searches i cannot seem to find a definitive answer,
car is a 69 camaro
will this bolt right in place of the old one?
will the oem shroud bolt up ?
will the old hoses work?
if none of the above are yes then what will i need?
Bill
BEECHFRONT is offline
post #2 of 32 (permalink) Old Jun 18th, 07, 01:30 PM
Re: Summit Aluminum Radiator
I would say yes to all of the above.
I needed to elongate the mounting holes a schosh. (less than 1/8")
There was nothing to attach the lower shroud clips to so I stuck em on with JB Weld.
Everything else was perect.
post #3 of 32 (permalink) Old Jun 18th, 07, 01:39 PM Thread Starter
Bill
Jim if i have not said it before ,you da man! thanks for helping me on quite a few post's
post #4 of 32 (permalink) Old Jun 18th, 07, 03:43 PM
just installed on a 68 - zero problems, and yes to all your ?'s
TSTONE is offline
post #5 of 32 (permalink) Old Jun 18th, 07, 04:33 PM
Bill: Helped friend a few months ago install one on His 69 took us less then an hour no problems. Brought temp down 10 degrees from original 3 row which was kind of worn out
edd Gordon is offline
post #6 of 32 (permalink) Old Jun 18th, 07, 04:41 PM
ditto - went from 210 down to 170 using distilled water and waterwetter
TSTONE is offline
post #7 of 32 (permalink) Old Jun 24th, 07, 11:10 AM
Can I ask what waterwetter is? I'm ready to order one myself. Thanks!
post #8 of 32 (permalink) Old Jun 24th, 07, 11:20 AM
http://store.summitracing.com/partde...5&autoview=sku
Brand: Red Line Synthetic Oil
Product Line: Red Line Water Wetter Cooling System Treatment
Part Type: Coolant Additives
Quarts Treated: 20 qt.
Volume: 12 fluid oz.
Rust and Corrosion Inhibitors Included: Yes
Quantity: Sold individually.
Coolant Additive, Water Wetter, 12 fluid oz., Each
Wetter water for better cooling.
Red Line Water Wetter provides corrosion and rust protection for modern aluminum and cast iron cooling systems. This unique additive reduces coolant temperatures by as much as 30 degrees F. It can be used in plain water to provide much better heat transfer properties and protection than glycol-based antifreeze, or added to new or used antifreeze to fortify inhibitors and reduce foaming.
TSTONE is offline
post #9 of 32 (permalink) Old Jun 24th, 07, 11:21 AM Thread Starter
Bill
im getting ready to order one tomorrow,
1 last question can you use your origional bottom hose on this radiator?
if not which one do i order?
i thought i read a few posts that the bottom hose outlet on the radiator was pointing upward on angle and that origional hose wont work.
post #10 of 32 (permalink) Old Jun 24th, 07, 11:30 AM
Thanks! Looks like good stuff!
post #11 of 32 (permalink) Old Jun 24th, 07, 03:02 PM
yes, you can use both your original hoses, your cap, and even your original petcock.
post #12 of 32 (permalink) Old Aug 21st, 07, 05:03 PM
Rob
RockinRob's Avatar
Bill (BEECHFRONT) did you ever get your radiator from Summit, and did it go in as planned?
What part number did you end up getting from summit?
Rob
67 base convertible, GMPP 350/330 HO, TKO500....
Taken around the block for the first time 12/2/07
Finaly getting some paint Sept. 2009
RockinRob is offline
post #13 of 32 (permalink) Old Aug 21st, 07, 06:37 PM Thread Starter
Bill
Rob
Rob i purchased the summit radiator and everything fit fine, im not sure on part number but i will look and post back.
post #14 of 32 (permalink) Old Aug 21st, 07, 11:39 PM
67 Camaros Rock
Joe Harrison's Avatar
What radiator is this?
-Mark Donahue
My 67 Camaro Time Line
Joe Harrison is offline
post #15 of 32 (permalink) Old Aug 22nd, 07, 09:35 AM Thread Starter
Bill
this is the radiator
Radiator Mounting Question South Side Goons & Hitmen Heating & Cooling 15 Dec 29th, 06 04:21 AM
Aluminum Radiator Comparison 69Nova Heating & Cooling 3 May 31st, 06 09:49 AM
Picking an aluminum radiator cdunson Heating & Cooling 1 Apr 11th, 06 04:12 PM
Aluminum Radiator Maples69 Heating & Cooling 3 Aug 17th, 04 09:29 AM
Aluminum heads vs. Cast Iron Heads peter19u Performance 67 Jul 15th, 03 02:16 PM
