1997 Camaro overheating - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 20th, 07, 08:05 AM Thread Starter
I have a 1997 Camaro 6cyl 3.8L. It has been having an issue with overheating. It's overheating at random times. When you're cruising about 70 on the interstate. The guage barely moves up from cold, when I think it should be running at a normal temp. In stop and go traffic especially, there is a problem with it overheating. The guage seems to go way up almost to the red and then the thermostat seems to kick in and it cools down. It does its own sort of dance, jumping from cold to hot. We keep it full of fluid. My husband has replaced the thermostat. What else should he change? Water pump? Radiator?
karpat2006 is offline
post #2 of 5 (permalink) Old Jun 20th, 07, 08:25 AM
DjD
DjD's Avatar
Re: 1997 Camaro overheating
Your car is having air flow problems when it is moving solw or standing still. That indicates the electric fans are not working properly or at least are not pulling enough air through the core. Since air gets through the core when the car is moving at higher speeds there is no problem with something blocking the core. The thermostat controls when the fluid flows through the system. There is another temp sensor that turns the fan on and off. Look at the fan and the sensor to solve your problem. Try turning on the AC (the cooling fan runs when the AC is on) and see if the temp runs more stable. How long have you owned the car? Is this something that just started happening? They do tend to let the temp build before the fans come on.
...Dennis
DjD is offline
post #3 of 5 (permalink) Old Jun 20th, 07, 09:34 AM
what kind of temps are we talking here? in the 80's, GM started making their engines run much hotter, and cars with electric fans tend to have a big temp range between when the fans kick on and when they kick off again- a 30 degree temp swing seems plausible given the on/off temps of the oem fan switches.
when going down the road, the radiator will keep the temp down in the 190 range where the t stat opens, but around town, the fans won't kick on until 235 or higher, and off at 210-215.
you don't plan sincerity.
novaderrik is offline
post #4 of 5 (permalink) Old Jun 20th, 07, 09:48 AM
Is there 1 or 2 fans?
The main fan should turn on around 220. The second, if there is one, won't turn on until 235 or so.
Both fans should ALWAYS run if the A/C is on.
I recently fixed a problem with identical symptoms on the 93 vette I just bought, the radiator was completely plugged with road crud, no airflow possible at all. Rem,oving and cleaning it fixed it right up.
post #5 of 5 (permalink) Old Jun 20th, 07, 11:18 AM Thread Starter
I just called the husband as I'm not sure whats under the hood. He says there are two fans.
The temp does run somewhat slightly more stable with the A/C on, yes.
It's funny because when it's in the stop and go traffic, It may/can get all the way up to the red (solid) area. But when its on the interstate and the temp doesn't go up at all? Not even to slightly warm?
I understand what novaderrik is saying about the thermostat waiting until higher to open, because my husband tells me to wait when I freak out that the temp gets up there on the scale, Inevetibly it does go back down.
I's my car and I've had it since 1999. This problem has been going on for a while, but its been parked several months as I reached 100,000 miles and thought I should get a new vehicle.
Thanks for your suggestions. I do appreciate them and anymore information would be great. I will take this home and let him know your suggestions.
Last edited by karpat2006; Jun 20th, 07 at 11:22 AM. Reason: Apparantly I can't spell.
69 Camaros on television and movies jsg1010z Bench Racing 35 Aug 15th, 10 05:28 PM
2 1969 ZL1 Camaro Prototypes 68Baldwin Copo & Dealer 57 May 11th, 09 05:43 PM
GM Insiders Tell Us How A Long-Awaited Dream - The New Camaro OverAnxious Fifth Generation 41 Aug 3rd, 06 05:13 PM
CAMARO IS BACK IN 2007!!!!!!!!!!!!!!!!!!!!!!!!! dawg Bench Racing 32 Apr 24th, 05 07:27 PM
90's camaro overheating , need help please! fathead Troubleshooting 4 Jan 13th, 03 02:53 PM
