AC Conversion to 134a - Team Camaro Tech
post #1 of 3 (permalink) Old Jun 21st, 07, 08:22 AM Thread Starter
DeAngelo
Question AC Conversion to 134a
Currently, I have refrigerant 134 in my 67. I have owned the car for 2 years and can only assume that the proper upgrades were made to allow it to handle 134. Everything appears original/OEM replacement and looks new. It blows cool but nowhere near cold. I was told to replace the POA valve but also read that I could adjust it with a turn of the screwdriver. The whole front end from the firewall forward had been disassembled to powder coat it and install a new engine and most parts are new. I read that if if you ever tore down everything, you should replace the dryer. I am not even sure if the current dryer was made for 134 in the first place. Should I replace the POA valve and dryer? Thanks, Hot in VA!
Deangelo66 is offline
post #2 of 3 (permalink) Old Jun 21st, 07, 10:30 AM
Vintage 68's Avatar
Cool Re: AC Conversion to 134a
Yes, the Dryer should be a 134 type to funtion best.
Hopefully the conversion was done correctly and the system will be fine if a few things are fine-tuned.
There is a very good chance that the POA valve, if not replaced, was never adjusted for the 134 conversion. Mainly because lots of info in print says 'they can't be adjusted' ... That is incorrect.
First - I would replace the dryer if it not clearly marked for 134 use.
Next - I would adjust the POA as follows;
1st - hook up the gauges and recheck low side pressure, it should be below 29~27 PSI. If the pressure is high, the valve probably needs adjusted (or the compressor is going bad - but we'll save that for later ... )
2nd - turn the adjustment screw out ( CCW ) @1/4~1/2 turn and recheck pressures, hopefully they will now be down where they should be.
3rd - recheck the internal outlet temps - they should be lower and you'll now be
Hope this helps;
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 3 (permalink) Old Jun 21st, 07, 10:43 AM Thread Starter
DeAngelo
Thanks, John! That is VERY helpful. I will get a shop to try this. The compressor is a brand new factory-looking one from Year One. I just found out that the dryer is for 134 and is brand new. And I assume the adjustment screw is a simple thing to find on the POA. Hope it gets cold now!! Thanks again! DeAngelo
AC Delete Conversion Milt's 68 SS/RS 396 Electrical & Wiring 2 Apr 20th, 07 11:59 PM
67 RS conversion on AC car Dark Angel Heating & Cooling 6 Mar 28th, 07 07:35 PM
AC vents always blowing hot air DPeter2101 Heating & Cooling 5 Nov 28th, 06 05:08 PM
Were to buy AC conversion? New67RS Heating & Cooling 5 Sep 13th, 06 05:58 AM
69 Deluxe Door Panel conversion and AC question?? lchb7 Camaro Tech 2 Feb 3rd, 06 05:27 PM
