Antifreeze woes - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 23rd, 07, 03:34 PM Thread Starter
Milt
Milt's 68 SS/RS 396's Avatar
Antifreeze woes
All right here is my latest dilemma. Edelbrock intake, edelbrock heads,new intake gaskets, chrome water neck with o-ring seal. Silicone on intake bolts, teflon tape on the heat sensor. My problem is after I run the car a small pool of antifreeze collects in the front drivers side corner of the intake. I can't tell if it's leaking from the bolt, the heat sensor or the water neck. Any suggestions?
Milt's 68 SS/RS 396 is offline
post #2 of 4 (permalink) Old Jun 23rd, 07, 03:43 PM
Re: Antifreeze woes
Take out the bolt and reseal it and put it back. Take out the tmep snesor and reseal it and put it back. Take off the water neck, make sure it and the manifold surface are flat, take the o-ring off, grease it with some white grease, put it all back?
sorry, Ima smartass today...
post #3 of 4 (permalink) Old Jun 24th, 07, 06:45 AM
Rex
Re: Antifreeze woes
I had a similar problem and pulled my chrome water neck and the was a hairline crack. 10 bucks and it was fixed until the next time.
69 x-11..LS1, 420.88 horse to the tires,750 Holley Ultra DP, Torquer V2, darksides headers, PRC heads, 10.8:1 compression, forged bottom end, 5 speed. 2008 King Ranch F150 4x4.
trex70 is offline
post #4 of 4 (permalink) Old Jun 24th, 07, 07:03 AM
Re: Antifreeze woes
My bet would also be the waterneck.
68 Camaro~LSx ~all motor
Throttle linkage woes... Musclecar Camaro Tech 6 Mar 18th, 07 07:30 PM
water or antifreeze mix? utility5 Heating & Cooling 6 Jun 24th, 06 05:34 AM
Antifreeze coming through intake manifold bolt? faninc Heating & Cooling 10 Oct 19th, 05 01:02 AM
Loosing antifreeze Ed Hericks Heating & Cooling 4 Mar 29th, 05 05:55 AM
antifreeze question SteveTheCamaroGuy Performance 6 Jan 14th, 03 03:08 PM
