should i be concerned??? - Team Camaro Tech
post #1 of 12 (permalink) Old Jun 24th, 07, 05:35 PM Thread Starter
Question should i be concerned???
I have 327 30over 180tstat - before replacing radiator i was running around 220f avg - i switched to an aluminum radiator running distilled water and water wetter and now am avging 175f - should i replace my tstat with 160 cause otherwise im concerned that it may not be opening?
Am i on base here???
TSTONE is offline
post #2 of 12 (permalink) Old Jun 24th, 07, 05:56 PM
Re: should i be concerned???
Nope.
You're car is cooling perfectly. The stat may open a lil early, or your gauge may be a touch off. She's getting all the cooling she needs.
I get about the same readings.
post #3 of 12 (permalink) Old Jun 25th, 07, 10:41 AM
Charlie
Todd,
What are you going to do in the winter? Distilled water and water wetter are not going to offer you any anti freeze properties what so ever not to mention that if you run straight water you are going to have rust forming where ever the water only goes. That is another benefit of coolant. It has rust inhibitors in it. If you have done something to deter this, please let me know because I would like my car to run that cool also.
67CamaroRS/SS is offline
post #4 of 12 (permalink) Old Jun 25th, 07, 11:02 AM Thread Starter
heated garage and the water wetter takes care of all the chemical properties needed for lubrication and anti-corrosion both rust (block/waterpump) and scale(aluminum rad)
TSTONE is offline
post #5 of 12 (permalink) Old Jun 25th, 07, 11:04 AM
Charlie
I have been running water wetter for a long time in both my car and my bike and I haven't seen anything about rust inhibitors.
post #6 of 12 (permalink) Old Jun 25th, 07, 11:05 AM Thread Starter
Here's some reading for you:
http://www.redlineoil.com/whitePaper/17.pdf
"WaterWetter®
WaterWetter® is a unique wetting agent for cooling systems which reduces coolant temperatures by as much as 30ºF. This liquid product can be used to provide rust and corrosion protection in plain water for racing engines, which provides much better heat transfer properties than glycol-based antifreeze. Or it can be added to new or used antifreeze to improve the heat transfer of ethylene and propylene glycol systems. Designed for modern aluminum, cast iron, copper, brass and bronze systems. Compatible with all antifreezes, including the latest long-life variations. "
TSTONE is offline
post #7 of 12 (permalink) Old Jun 25th, 07, 11:11 AM
Charlie
I was reading what Redline says about their Water Wetter and they say that Water Wetter should never be used with just water. Some antifreeze is necessary. They say that even in the summertime the a/c can blow freezing air thru the heater and cause freezing of the heater core unless at least 20% antifreeze is used.
post #8 of 12 (permalink) Old Jun 25th, 07, 11:13 AM
Charlie
Read their tech info on Water Wetter. It says exactly what I just said under the "USE" heading.
post #9 of 12 (permalink) Old Jun 25th, 07, 11:14 AM
Charlie
Straight water and Water Wetter only is for on track use only. Not street driven cars. Even if you think you have a "race engine", that combo is for the track only.
post #10 of 12 (permalink) Old Jun 25th, 07, 11:15 AM Thread Starter
why are you fighting me on this - we are obviously not in the same boat
I don't have a/c - I do have a heated garage (never gets below 45f)
statements are as follows from the white sheet i posted
"If the vehicle will see freezing temperatures, an antifreeze must be used."
TSTONE is offline
post #11 of 12 (permalink) Old Jun 25th, 07, 11:18 AM Thread Starter
the statements you are making are out of context - if you read the entire "use section" statement your interprtaion only applys if using tap water - as stated above i am using distilled
TSTONE is offline
post #12 of 12 (permalink) Old Jun 25th, 07, 11:24 AM
Charlie
Ok.
Engine Temperature - Should I be concerned? 69banana Heating & Cooling 14 Jun 6th, 07 04:14 AM
Anything to be concerned about w/99 SS Convertible vrdn1 Camaro Tech 6 Aug 14th, 04 09:00 AM
Should I be concerned? oldcarman49er Engine 4 Sep 6th, 03 11:48 AM
