Replacing heater core and blower housing - Team Camaro Tech
post #1 of 3 (permalink) Old Jun 25th, 07, 09:29 AM Thread Starter
TB
Hi All, I am a rookie so please cut me some slack . I am currently doing a complete re-build of my 68 RS. I am replacing my SBC and am putting a BBC in it's place having challenges removing the blower housing. I have removed the core from inside the car and refurbed the heater box. Now I am trying to remove the blower case from within the engine compartment. I have lossened the the lower fender bolt and tried to use the 2x4 method on the inner fender well to remove the housing, but the blower motor gets in the way. Will I have to remove the fender to finish this job? If so is that easy to mess up? Trying to finish this job so I can paint my engine bay.
68BBRS is offline
post #2 of 3 (permalink) Old Jun 25th, 07, 11:07 AM
Re: Replacing heater core and blower housing
You will have to remove something to gain room. The 2X4 method is not enough room.
Some remove all the inner fender bolts and let it drop to the upper control arm and give room. Others remove the fender/inner fender as one. Both are about the same amount of time.
I would probably do the inner fender.
Everett#2390 is online now
post #3 of 3 (permalink) Old Jun 25th, 07, 11:11 AM Thread Starter
TB
Thanks for the info. So I should remove all of the inner fender bolts and just drop it down. Looking at it, do I need to remove core support etc? looks like it's all bolter together.
68BBRS is offline
Heater core seal necessary? italiano362 Heating & Cooling 5 Jan 5th, 07 10:01 AM
Heater core seal necessary? italiano362 Heating & Cooling 1 Jan 5th, 07 04:17 AM
BB heater box,core and seal kit? Where to find one? mnm99 Heating & Cooling 9 Nov 1st, 06 11:08 AM
1st gen heater core 68camaro496 Camaro Tech 3 Feb 8th, 06 08:58 PM
Heater blower and core delete panels Liveinaz Heating & Cooling 5 Oct 31st, 05 02:49 PM
