big block radiator - Team Camaro Tech
post #1 of 7 (permalink) Old Jun 25th, 07, 09:49 PM Thread Starter
big block radiator
My 396 conv. still has a small block radiator. What is the best radiator to mtch my 350 hp engine with automatic transmission? I want to keep it looking fairly stock, though a little chrome would be great. By the way, why are there different radiators for manual vs automatic trasmission?
68fan is offline
post #2 of 7 (permalink) Old Jun 26th, 07, 02:14 AM
Re: big block radiator
some radiators for automatic transmissions have the trans cooler in them and/or have provisions for trans cooler lines built into them. That is why they are different.
Does your 1968 have factory a/c? If so it should have the "big" block radiator. If not then a 4 row/4 core copper & brass radiator will do just fine for your 396. That's what I had on my first 1969 Camaro years ago. The 4 row/4 core copper & brass radiator will "match" the look of the era
Aluminum will work as well. Just don't overpay for one. There are several good manufacturers of aluminum radiators. I have aluminum in my car now.
I like both copper & brass radiators and aluminum radiators.
1) 1969 Camaro RS 396 TH 400, 12 bolt 3:73 sold 1994
2) 1984 Z28, 5.0 H.O. T-Tops, G92 3:73, sold 1994
3) 1988 5.7L IROC-Z, sold 1994
4) 1969 Camaro bought 2006, back on the road in 2010
post #3 of 7 (permalink) Old Jun 26th, 07, 02:55 PM Thread Starter
would this be a 23" or 21" radiator. Mine is automatic.
68fan is offline
post #4 of 7 (permalink) Old Jul 2nd, 07, 02:02 PM Thread Starter
I'm assuming 23" 4 core
68fan is offline
post #5 of 7 (permalink) Old Jul 7th, 07, 08:54 PM
we build both sizes in aluminum
http://www.chevellecooling.com/44.ht...2oQlLR&sm=2764
here to help with cooling solutions
Alumitech Reproductions
517-404-6262
alumitech is offline
post #6 of 7 (permalink) Old Jul 8th, 07, 05:56 AM
Griffin radiators have die stamped end tanks that resemble the stock radiator when painted with radiator paint (not a rattle can of black enamel), as compared to the equally effective in terms of shedding heat fabricated end tanks of BeCool and others.
Larger Dave
Larger Dave is offline
post #7 of 7 (permalink) Old Jul 8th, 07, 12:51 PM
Fred
Here's a look at my new Griffin. I cut off the mounts because I built a tray for my radiator to sit on, like '70 and later GMs. This is an exact replacement rated for 600 HP except it's two-core, not four. (more efficient) The cooler lines bolt right up. Got it at Summit.
128.79mph 1.428 60'
Fred Ficarra is offline
Big Block VS small block AC suitcase 68 Ragtop Tag Team 7 Oct 6th, 06 04:12 PM
Who's got Big block springs in a small block? mnm99 Brakes, Suspension & Steering 1 Sep 8th, 06 12:22 PM
Is a 427 a big block or small block? chedderboy Camaro Tech 8 Apr 29th, 06 07:07 PM
Small Block or Big Block PDW HOTRODS Performance 25 Dec 19th, 05 06:21 PM
big bore x short stroke big block?? Skeletor Performance 9 May 19th, 05 04:47 PM
