Electric fan pushing and clutch fan - Team Camaro Tech
post #1 of 34 (permalink) Old Jun 27th, 07, 07:47 AM Thread Starter
Cool Electric fan pushing and clutch fan
I have a 69 big block with a 3 core radiator , clutch fan and a electric fan pushing, the motor has less than 100 miles on it but it wants to run at 205-210 degrees on 90 degree days i'm running a 160 degree thermostat is the electric fan fighting against the clutch fan is it a good idea to run both ? any help would be great.
jr little is offline
post #2 of 34 (permalink) Old Jun 27th, 07, 08:01 AM
Charlie
Re: Electric fan pushing and clutch fan
First I would start by removing one of the fans. You only one fan. Second, switch to a 180 degree thermostat. That will allow a more even system. I had a 160 in my small block with an electric fan and the car always ran above 200. i switched to a 180 and now the car stays at 180-190. On the highway and cruising. Just a thought.
67CamaroRS/SS is offline
post #3 of 34 (permalink) Old Jun 27th, 07, 08:07 AM Thread Starter
Thanks I'll try that
post #4 of 34 (permalink) Old Jun 27th, 07, 08:08 AM
DjD
DjD's Avatar
jr - the electric pusher fan may be blocking the core and restricting air flow through the core. this really becomes an issue when driving since the natural flow of air is normally greater then anything a fan can generate...
...Dennis
DjD is offline
post #5 of 34 (permalink) Old Jun 27th, 07, 08:22 AM Thread Starter
I ran without a electric before but if I had to sit in stopped traffic for any length of time the temperture would get in to the 250 range so I added a electric fan that I manualy turned on and that helped With the new motor I installed a sensor that is adjustable and i'm not sure it has helped.
post #6 of 34 (permalink) Old Jun 27th, 07, 08:28 AM
Charlie
I removed my clutch fan and installed an electric fan. I installed a 180 thermostat and now the car stays between 180-190, even idling. My electric fan is a 16" and pulls 3985cfm.
post #7 of 34 (permalink) Old Jun 27th, 07, 08:40 AM
DjD
DjD's Avatar
With electric a puller is the only way to go. I have no problems with a clutch fan cooling my stroker engine using a stock water pump and a re-cored stock tank radiator.
jr - when you had 250 idle temps you were not getting enough flow through the core. You also may have had improper timing or a mechanical issue with your engine. If your radiator, water pump and t-stat are in good condition, you have a bit of idle advance say 10-12 degs and the fan is in the shroud properly and if you have a fan clutch it is operating correct you won't have your previous problems.
Electric fans work but are not necessary to cool an engine. They came about because of space or actually lack of space in modern cars...
...Dennis
DjD is offline
post #8 of 34 (permalink) Old Jun 27th, 07, 09:38 AM Thread Starter
Thanks everyone a lot of good advise i'll be trying.
post #9 of 34 (permalink) Old Jun 27th, 07, 10:40 PM
Strick
I too had this problem (briefly) on my '55. Either remove the front fan and install a shroud for the clutch fan, or remove the clutch fan and us the pusher as a puller (most will reverse with a wiring change and flopping the blades), but still use a shroud. I normally use a 180 thermostat, but the 160 is O.K. for now.
Strick
Strick is offline
post #10 of 34 (permalink) Old Jun 28th, 07, 07:12 AM Thread Starter
Last night I reset the pusher to come on at 190 degrees and kept the clutch fan and shroud in place it got to 205- 210 while sitting in the driveway once i srarted driving it went down to 190-195 and stayed there but because of rain I was only able to drive for about 15 min. I still don't like it over 200 at idle.
post #11 of 34 (permalink) Old Jun 28th, 07, 09:35 AM
Charlie
You only need one fan. Having a fan in front of the rad. is impeding air flow. Move the electric around to the other side of the rad. and switch the wires so it pulls air instead of pushes it, install a 180 thermostat, make the fan come on at 185 and go off at 170 and all should be good. You also need to make sure the fan moves enough air. If you have a/c then thats going to make a difference.
post #12 of 34 (permalink) Old Jun 28th, 07, 11:05 AM
Okay... with all due respect (I am trying my more soooooothing, touchy-feelie approach since DJD reprimanded me for my last few posts as coming off "just because I said so" approach... and I just am tying to be pithy really!) So, here goes!
Whether the fan is in front or rear.. there is NO appreciable difference in the blockage unless the air has no where to flow around the fan. This is why a shrouded fan in front would indeed block air. So, if you put a standard 16" pusher on front, it's not going to have an appreciable affect on the incoming air so to speak different from that from being mounted on the rear. I have run fans for years without problems on the 55-57 series just like that and have pushed upward of way over three digit cruising without a fuss? And, recent OEMs have been putting augmentor fans on the front of their radiators to improve "stoplight" or "idle zone" efficiencies.
Here is a picture...
and by the way... this is the ONLY fan I have on a 383/450hp engine with air in Atlanta... and works great!
Now... does a "puller" work better? Yes in efficiency only. BECAUSE the air flow coming into the "puller" fan is unfettered air so to speak, and the air coming thru a "pusher" is disturbed and eddy currents can redirect some of the air outside the working footprint of the fan.
That's my story and I'm stick'in to it!
Steve "Jack'stands" Jack
HOTRODSRJ is offline
post #13 of 34 (permalink) Old Jun 28th, 07, 12:36 PM
Charlie
I have NEVER seen a factory installed fan mounted on the front of a radiator. If you can show me one then I would stand corrected, but until then NEVER. ;(
post #14 of 34 (permalink) Old Jun 28th, 07, 02:07 PM
Harley
wiskeesour's Avatar
Talking Re: Electric fan pushing and clutch fan
Charlie, on American or Imports? My 90 Iroc-Z has twin fans on the front....
Eclipse have them on the front.
My Dakota w/5/9L is in the front on the side for the Trans AND in the back for the Rad...
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #15 of 34 (permalink) Old Jun 28th, 07, 02:18 PM
Apparently you have a sheltered life... But, I do study this stuff for a living..so I expect there to be these moments.
There are a lot of applications now doing this both foreign and domestic. And, we all know the Germans to be engineering fanatics.... well... take a peak at the new BMW X5s for example. Peak thru the front valence and see the huge "pusher" fan inside. Or go here for a preview!
http://rides.webshots.com/photo/1268...38884788smBuyy
Enjoy.
It's not nice to mess with Dr. Cooling?
Won't shift into second (M21) and clutch question Calpantera Transmission & Driveline 5 Jun 17th, 05 04:04 AM
hydraulic clutch?? drognar Transmission & Driveline 1 Oct 30th, 03 08:35 AM
