Water Pump - Team Camaro Tech
post #1 of 3 (permalink) Old Jun 29th, 07, 08:29 AM Thread Starter
Water Pump
Hey guys. I am a female, wanting to do my own repairs on my car. Primarilly because I don't trust any of the local mechanics. How hard is it to remove and reinstall a water pump for a 1997 camaro z28, LT1 350, six speed, using the Hayne's Camaro repair manual for my guide?
castor8or is offline
post #2 of 3 (permalink) Old Jun 29th, 07, 12:09 PM
Robert
Re: Water Pump
I would think you could do it. I'm sure you will get plenty of help here if you need it. I think more inportintly is that you have the proper tools to do the work with.
There are no problems only solutions
68 Camaro, RS/SS, ZZ502, Retrotek Fuel Injection, 4 Speed.
2010 RS/2SS Black, 6 speed trans
68Holdon is offline
post #3 of 3 (permalink) Old Jun 30th, 07, 09:18 PM
Re: Water Pump
I agree, go for it.
The only issue I can forsee is the water pump on your LT1 is driven mechanically from the timing gear instead of from a belt like most engines. The water pump has a splined shaft the protrudes from the rear and there is a shaft that protrudes from the timing cover that are joined together by a splined sleeve. Sometimes the sleeve comes off with the water pump and sometimes it stays on the shaft from the timing cover. Just be sure the sleeve is in place when the new water pump goes on. Other than that, it's pretty much a straightforward water pump job.
Your Hayne's manual should cover it nicely, but don't be shy about asking questions here.
Edit: On your LT1, the distributor is behind the water pump. Now would be a good time to replace the distributor cap and rotor.
red67camaro is offline
327 with short water pump and running the fuel line woes 30lbtest Engine 12 May 3rd, 07 02:05 PM
short water pump or long water pump??.... PLT-1 Engine 5 Jan 28th, 06 08:47 AM
Water Pump 62bakes Engine 5 Nov 5th, 03 05:55 PM
Water Pump Woes… Z28 Mark @home Performance 7 Nov 5th, 02 03:38 PM
short water pump vs long water pump mark67ss Tech 2001 13 Oct 18th, 01 05:45 AM
