Need Dimensions of Lower Rear AC Compressor Spacer - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 30th, 07, 01:09 PM Thread Starter
Charlie
Hi everyone,
I can't seam to find this part for my 69 Small Block Camaro and need the dimensions (length, diameter and hole size) for the Lower Rear AC Compressor SPACER so that I can fabricate something similar. It's part number 3841722 and it's shown in the Factory Assembly Instruction Manual on page 212 as Number 12. Of course, if anyone has one of these that they are willing to part with, that would be even better! Thanks, Charlie
camaromaniac is offline
post #2 of 4 (permalink) Old Jun 30th, 07, 01:25 PM
click's Avatar
Re: Need Dimensions of Lower Rear AC Compressor Spacer
Charlie my lower rear compressor bolt hole bracket bolts direct to the exhaust manifold bracket with no spacer. My upper bracket that bolts to the intake bolts, has a gap of 1 7/8" and the spacer it self is 1.5" with 3 small washers making up the difference. Either you or I might have the wrong lower bracket then?
click is offline
post #3 of 4 (permalink) Old Jul 1st, 07, 11:38 AM Thread Starter
Charlie
Jim,
My 69 has the original 350, ac compressor and front brackets, but when I got the car it had headers. I then located an original set of 69 exhaust manifolds that had been on an ac car and thanks to some really great guys here on tc, I now have the correct upper (GM part No. 3932436) and lower (GM part No. 3932435) rear brackets. Rick's 1st Generation is sending me the upper rear spacer (GM part No. 3932437), but they don't stock the lower rear spacer (GM part No. 3841722). I'm specifically referring to page 212 of the Factory Instruction Assembly Manual and VIEW A. There it shows the SPACER (referenced as part 13) with a GM part number of 3841722. Does that help? Thanks, Charlie
post #4 of 4 (permalink) Old Jul 1st, 07, 04:27 PM
mark
mark x22's Avatar
.75 diameter .75 long steel .
mark x22 is offline
Door adjustment jsouthco68camaro Body Shop 9 Mar 7th, 05 05:46 AM
Trunk Lid Fit Problem RPOL72 Body Shop 8 Aug 27th, 03 01:45 AM
Hood adjustments!! Handy69Z Body Shop 2 Mar 13th, 03 04:14 AM
Best way to lower the rear of a 69 camaro, tire size 69 money pit Body Shop 1 Jan 2nd, 03 12:53 PM
Hanging Doors ? wesley58_do Body Shop 6 Jan 30th, 02 11:23 AM
