Fan not functioning properly - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 6th, 07, 06:24 AM Thread Starter
I have an 89 RS with the 305(V8). My radiator fan stoped turning on by itself. So i went and replaced every sensor on the block that delt with the fan and cooling system. While it wasnt working i was using a toggle switch and contoling the fan manually myself. So i know its not the fan itself. After replacing everything i wired it back to normal and it work fine by itself for a day and a half. Now its not working again. Does anyone have an idea.
HAULINanBALLIN is offline
post #2 of 4 (permalink) Old Jul 6th, 07, 06:57 AM
Rich
Re: Fan not functioning properly
More than likely it is the relay..... try replacing it first.
Cyclone is offline
post #3 of 4 (permalink) Old Jul 6th, 07, 07:02 AM Thread Starter
It has a brand new 1. That was replace when i replace the thermostat, the cooling fan switch on the bottom of the block, and the other cooling sensor on the top of the block. Ive got the old one and i know it still works so ill try that.
post #4 of 4 (permalink) Old Jul 6th, 07, 01:18 PM
Charlie
Did the car ever actually over heat where the coolant boiled over? If so, then that automatically destroys the coolant temp sensor. That will have to be replaced, no if's about it, but only if the car boiled coolant.
67CamaroRS/SS is offline
clutch fan wobble KURT Heating & Cooling 5 Jul 23rd, 06 05:24 AM
Flex fan being trashed/why not weld a clutch fan? wheezer Heating & Cooling 4 Jul 15th, 06 05:06 AM
Another clutch fan question . . . Mark Rossiter Heating & Cooling 1 Jun 16th, 06 09:36 AM
68 Z28 fan blade dimensions bwhitfield Heating & Cooling 2 Apr 4th, 06 07:50 AM
Cooling Fan Question SKIPS69 Heating & Cooling 10 Sep 6th, 05 08:31 PM
