thermostat - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 7th, 07, 04:22 PM Thread Starter
Bill
thermostat
i just installed a 180 high flow mr gasket thermostat and i also have high flow pump and high flow march pully system. started car and let it idle for 1/2 never went above 140, i thought the guage was wrong so i changed it out and same thing 140, drove around pretty hard for about a hr never went above 160 and that was when i was in 5th gear, dropped back down to 4th 140 again temp outside was 87 degrees.
Upper hose felt pretty hot, passengers side of radiator felt cooler then drivers side
Not complaining but i thought the temp should rise to at least 180 or above for the thermostat to open?
car has summit aluminum radiator, and stock sb shroud with flex fan half way in the shroud and water wetter, guage is mechanical
any input?
thanks
Bill
BEECHFRONT is offline
post #2 of 4 (permalink) Old Jul 7th, 07, 06:36 PM
Bruno
Lightbulb Re: thermostat
Some high flow thermostats have water flowing thru them, even when closed. At least the Stewart's have three holes to let water thru when closed. I think you have everything to get the lowest temperature possible. Maybe removing the flex fan, and using a thermal clutch one, can help increase the temp a bit. I live in a hot weather, and I don't like my car running at 140° tho. JMO
"Our affair with Camaros is a life sentence without the possibility of parole".
ORENCH is offline
post #3 of 4 (permalink) Old Jul 8th, 07, 05:58 AM
Re: thermostat
Indeed... if you have holes drilled in your thermostat (that aren't really necessary for 99% of the applications because they have by-passes built in) this will compromise the thermostat's function of regulating operating temperatures.
If you DON'T have holes in the thermostat... either the thermostat is sticking open (which is what they are supposed to do when faulty) or the temperature gauge is still off. Take an IR gun and shoot the top of the housing to see if it's in the ballpark.
Steve "Jack'stands" Jack
HOTRODSRJ is offline
post #4 of 4 (permalink) Old Jul 9th, 07, 06:24 PM Thread Starter
Bill
Re: thermostat
i checked my thermostat and it does seem to have some water flowing through it when it's closed, checked it in boiling water and it works, so i just switched over to stock thermostat and now it seems to get upto 180 and stays there.
coolant and thermostat Cpz28 Heating & Cooling 6 Jan 30th, 07 12:14 PM
aluminum intake and orange thermostat housing johnny67 Restoration Corner 10 Oct 25th, 06 06:30 AM
Fan thermostat jrt67ss350 Tech 2002 4 Jul 12th, 02 05:41 PM
Adjustable Thermostat or Not? ohayden Engine 6 Aug 10th, 01 11:36 AM
Thermostat By-pass Question Rons68 Engine 13 Feb 12th, 01 06:36 AM
