Hot Running - Team Camaro Tech
post #1 of 20 (permalink) Old Jul 8th, 07, 07:35 AM Thread Starter
Charlie
Hot Running
Here is my situation. I have a 350sbc in my Camaro and up until yesterday it would run between 180-190 no matter the temp. I have an electric fan. 180 therm., and it's wires to come on at 185 and go off at 170. Yesterday I was on the highway and it shot up to 220. I turned the heat on and it dropped to 210. It has never done this until yesterday. I pulled the therm. and it started to open at 170 and fully opened by 185. I ran a compression test on the motor and no problems there. Last night when this was going on the top hose was hard, very very hard. My coolant does not look milky. It's not boiling over. Not down on power. I did notice that when it was hot the oil pressure dropped to 30psi when it's normally 50 and it didn't want to idle very well in gear or park, but when it cooled it idled fine and the oil pressure went back up to 50. I am stumped. Anyone have any suggestions I can try? I am open to anything at this point. Thanks in advance.
67CamaroRS/SS is offline
post #2 of 20 (permalink) Old Jul 8th, 07, 01:35 PM
Steps
Re: Hot Running
Flush the radiator....better still pull it out, remove the hearders and manually clean....
Also check that the bottom hose reenforcing spring inside has not corroded away....this stops the hose from collasping from the water pump sucking....
Also a sytom that u have cores blocked.
Steptoe is offline
post #3 of 20 (permalink) Old Jul 8th, 07, 01:43 PM
Re: Hot Running
Ah, a fellow East Coaster, welcome to heat & humidity. It was hot yesterday and engines do run hotter and oil does thin out more.
Nothing much you can do except put electrical tape over the gauge so you can't read it.....LOL. You've found nothing wrong, unless there is less air going across the radiator or recycled air going through it.
The important thing is to prevent from boiling after shutdown, heat soak. You'll hear the boiling aftree it stops and heat builds up. Its important to keep the coolant pressurized to prevent boiling, as evidenced by the tight top hose. I have a 22 lb cap on my 454 dually to prevent it from boiling. Its running 220-230*f these days.
post #4 of 20 (permalink) Old Jul 8th, 07, 03:50 PM Thread Starter
Charlie
Re: Hot Running
Both the radiator and bottom hose are new. I don't understand it because he in Maryland last week it was mid 90's and the car ran at 180-190 all day. Yesterday at 8pm it was no where near that and the car ran hot. Here is some new info from the testing. I left the cap off after pulling the therm. and refilling the rad. and I never saw any coolant movement. The therm. opened because I saw that on the gauge. The water pump isn't making any noises and it's not leaking out of the drain hole.
post #5 of 20 (permalink) Old Jul 8th, 07, 09:12 PM
Re: Hot Running
i live in florida and lattle the cars are coming into my shop running hot. if the car is driven alot the rad fins get blocked with bug dirt etc. get a air hose and blow air from the engine side out to the front. see if you blow out a lot of dirt.(WITH THE ENGINE OFF) if you do back flush the fins with garden hose. will also help with your a/c pressure. 220-230 is a little hot for my liking. next get somthing like a raytech it will take the temp of what ever you point it at you gauge or sender may be wronge. if it is getting hot and the thermostate is out and your not getting any coolant flow youll have to take the water pump of and check the fins, it may be the only way to be 100% shure it ok. good luck.
obriens69 is offline
post #6 of 20 (permalink) Old Jul 8th, 07, 10:38 PM
Steps
Re: Hot Running
Some yrs back, had a very similar thing, only ever seen it once...
A new pump, didnt see too many miles...
As a last pitch effort pulled the pump and cover, the impeller had slipped and turning on the shaft splines...it still gripped a little....
So as couldnt get another pump for a while, spot weled the impeler, the pump lasted for a few more yrs when the seals/bearings finally gave up the ghost.
Steptoe is offline
post #7 of 20 (permalink) Old Jul 9th, 07, 04:32 AM
Re: Hot Running
With the engine idling, it would be hard to see coolant flowing. Need to reach over and increase rpm alittle.
Then, the fluid will drop and you should see coolant coming out of the tubes into the tank.
post #8 of 20 (permalink) Old Jul 9th, 07, 05:21 AM
Tim
77wolf10.85's Avatar
Re: Hot Running
Charlie
How is the fan activated?
Is there a sensor you stuff into the radiator fins? I have found those to be very erratic.
Also I have found a few that the wiring connections close to the relay were burned up and causing erratic fan operation.
Tim Smith
77wolf10.85 is offline
post #9 of 20 (permalink) Old Jul 9th, 07, 05:26 AM Thread Starter
Charlie
Re: Hot Running
The thermostat was in the car and I even throttled the engine a little to see if the fluid would move. The level dropped a little, but I still couldn't see movement. The sender can't be bad because when it said it was hot I noticed a drop in oil pressure and shotty idle. The car had no debree in the fins. It was actually very clean. The therm. works. Begins to open at 170 and is full open by 190. The cap holds 16psi just like it's rated. The only thing is the pump. I thought it was rather new and I have not neglected the cooling ststem so I can't see the impeller fins being rotted away. I don't hear any noise coming from the pump so I don't think the impeller has seperated from the shaft.
post #10 of 20 (permalink) Old Jul 9th, 07, 09:46 AM
Re: Hot Running
Reads like everything is working okay. You might need a larger diameter crank pulley to overspeed the w/pump and to pull more air through.
Maybe an additional Kwik Kool plate added on to the impeller to enclose it.
post #11 of 20 (permalink) Old Jul 9th, 07, 10:00 AM Thread Starter
Charlie
Re: Hot Running
I don't understand because the car ran fine it hotter weather then I had Saturday. The electric fan and everything else worked perfect until Saturday. It was only about 82-85 on Saturday at 8pm and the previous weekend and even earlier that day it was hotter than 90 and it ran right at 180-190. Something had to stop doing what it's supposed to when I went out at 8. The only thing I haven't removed is the pump and I think thats next. Today actually.
post #12 of 20 (permalink) Old Jul 9th, 07, 01:50 PM
Steps
Re: Hot Running
When u look at the impeller, it may not simly be spinning free...mine still turned and appeared tight, untill i put a wrench on it and it slipped.
Steptoe is offline
post #13 of 20 (permalink) Old Jul 10th, 07, 04:59 AM Thread Starter
Charlie
Re: Hot Running
Tim,
The fan is activated by a Painless fan switch in the intake manifold. On at 185 and off at 170.
post #14 of 20 (permalink) Old Jul 10th, 07, 05:01 AM Thread Starter
Charlie
Re: Hot Running
I am going to take the pump off Saturday. I was going to do it yesterday, but it was 100 in the shade in Baltimore. If the heat lets up I'll do it sooner, but I don't see that happening. It's already like 90 at 8am today.
post #15 of 20 (permalink) Old Jul 10th, 07, 06:35 AM
Re: Hot Running
I don't think it is the pump, but I could be wrong.
Slack dog! It was heat index of 93* here at the Beach at 8 AM. Tomorrow is more of the same. My home A/C has not shut off and house is approved R-36 by the electric company.
Vibration and #6 Cylinder Running Hot Mkelcy Engine 1 Aug 16th, 06 06:58 PM
Running Hot HO69 Transmission & Driveline 3 Aug 8th, 06 04:28 AM
Rebuilt 396 running really hot foreverlookin Heating & Cooling 12 Oct 19th, 05 07:21 PM
502 runs way too hot!!!! catrancher Heating & Cooling 6 Sep 11th, 05 05:43 AM
running hot deang423 Camaro Tech 4 Aug 10th, 05 02:35 PM
