Radiator I.D. - Team Camaro Tech
post #1 of 3 (permalink) Old Jul 16th, 07, 04:17 AM Thread Starter
Ken
Radiator I.D.
I could use the help of some of you Pros in identifying the radiator in my '68'. From other #'s on the car, it was born a base model V8, probably w/AT. The radiator has a brass tag built into the fin construction with the following info on it: upper left corner has two inverted 'V's, upper right corner has the number '19', middle has the number '3750337', across the bottom is 'Made In USA'. The radiator measures 21" x 17" w/ 3 rows and an A/T cooler. Any help w/ the ID would be greatly appreciated.
thank you,
Ken
KEN F '68' is offline
post #2 of 3 (permalink) Old Jul 16th, 07, 04:26 AM
Kevin
KevinW's Avatar
Re: Radiator I.D.
Sounds like a replacement rad. Does it have 2 round holes drilled through the upper and lower supports?
Kevin
KevinW is offline
post #3 of 3 (permalink) Old Jul 16th, 07, 04:57 AM Thread Starter
Ken
Re: Radiator I.D.
Kevin, I will have to check on that, as the rad. is at home, but it has the same side mounting brackets as an OEM and hole pattern that matches the rad. support. Thanks for your reply and I'll check for the holes tonite.
Thanks again.
Ken
