Fan hitting the shroud - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 31st, 07, 07:19 PM Thread Starter
I tried to put my new fan shroud on today (car never had one) and found out that the 19 1/2 fan blade hits the 20" shroud. The fan isn't exactly centered. Can i buy a 17" fan ,that bolts on the clutch part of the fan? If so can i get it at a local auto parts store say Advanced or autozone, napa? The shroud is for a 69 sb no air. Just what i thought i needed
Thanks ,Jim.
P.s does anyone need a 6 blade fan?
69 Plain Jane, Pennsylvania.
pa69cam is offline
post #2 of 6 (permalink) Old Jul 31st, 07, 07:27 PM
DjD
DjD's Avatar
Re: Fan hitting the shroud
figure out why your fan doesn't center up... Core support alignment, rad core on the core support or engine mount or tower. You'll be so much ahead of the game by fixing the problem as opposed to working around it.
...Dennis
DjD is offline
post #3 of 6 (permalink) Old Jul 31st, 07, 08:00 PM Thread Starter
Dennis, I would go that route if it was an origional engine, rad. support, radiator....ect. I think there are too many variables to be looking for the 1/4 inch its off. I'm ready to get driving and this is my last stumbling block. I want to try to find a smaller fan. I just got in from the garage and thought i'd ask. Thanks man
pa69cam is offline
post #4 of 6 (permalink) Old Jul 31st, 07, 08:08 PM
Farm Boy's Avatar
67-69 Camaros use an 18 inch fan.
Farm Boy is online now
post #5 of 6 (permalink) Old Jul 31st, 07, 08:23 PM
Farm Boy's Avatar
Hayden has an aftermarket 18 fan that is designed to bolt to a fan clutch. The part number is 3618. Parts America has them for $30
You can also find 18 fans in the wrecking yards. I recently picked up a cherry 18 inch seven blade clutch fan out of a 79 Cadillac Seville for only $9.
post #6 of 6 (permalink) Old Jul 31st, 07, 09:09 PM
Jim -
if you want a new GM steel 7 blade, 18-inch clutch fan the number is 393996. It's about $70 from GM Parts Direct, and your local dealer might sell it to you for wholesale. It's what I run and it fits great and looks relatively correct.
Eric
Eric Kammerer is offline
