my camaro got up to 240 then I shut it down - Team Camaro Tech
post #1 of 10 (permalink) Old Aug 3rd, 07, 06:40 PM Thread Starter
Johnny
Unhappy my camaro got up to 240 then I shut it down
I hope I did not damage anything. It was boiling down the overflow I put aprox 1 gal. of anti freeze and the rest water. I have a 396 that is bored 30 over with a new stock- 4 core rad automatic, water pump, fan shroud, 5 blade fan with a clutch, 180 thermostat, and a tranny cooler in front. The car is running great and it is only 72 F outside but I was in heavy traffic for at least 40 min.
http://,
67Camaro 396BB 750Holley, edlebrock performer,280isky,3.42 posi, turbo 350,stage 2 shift kit, 2800 stall, MSDready to run distributor, headers, 2.5"exhaust, Hotchkis(1.5"/2"drop).(orig.Deep water blue/light blue dlx inter, v8 column shift/bench seat)
johnny67 is offline
post #2 of 10 (permalink) Old Aug 3rd, 07, 07:01 PM
Re: my camaro got up to 240 then I shut it down
i wouldnt worry johnny...you really have to cook the hell out of an iron headed motor to hurt it...maybe you should add a pusher for those traffic riddled days...just a thought...
kustomwerker is offline
post #3 of 10 (permalink) Old Aug 3rd, 07, 07:04 PM
Erik
I have had mine get really hot like that also and all was okay. What radiator do you use? I have a stock 3-row. Was thinking of going to 4-row.
Erik
67
with original 350/295
erik67ssrs is offline
post #4 of 10 (permalink) Old Aug 3rd, 07, 07:04 PM
"Tri-Tip"
Gary L's Avatar
How is your timing set up? Retarded timing can cause over-heating issues.
Gary L is offline
post #5 of 10 (permalink) Old Aug 3rd, 07, 07:05 PM Thread Starter
Johnny
lol, yeah thats good to hear. The engine still sounds okay.
I checked the clutch and it has 3/16 of play in it but no oil on the front spring and it has some drag to it when I spin it.
johnny67 is offline
post #6 of 10 (permalink) Old Aug 3rd, 07, 07:07 PM Thread Starter
Johnny
Its a stock 4 core from US radiator. I am not sure about the timing but I can call my mechanic. It has a mild cam in it I believe its a 280.
johnny67 is offline
post #7 of 10 (permalink) Old Aug 3rd, 07, 07:17 PM
Andrew
Andrew69's Avatar
Oh, you are talking about temperature. I thought you were talking MPH! I was going to congratulate you.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #8 of 10 (permalink) Old Aug 3rd, 07, 07:20 PM Thread Starter
Johnny
lol, I'm afraid to take my eyes off the road to look at the speedo when my car gets goin that fast.
johnny67 is offline
post #9 of 10 (permalink) Old Aug 3rd, 07, 08:23 PM
luke
after a nite of racing i lost a fan belt driving home and tried to make it without stopping. i was about 1 mile from my house and blew the upper hose off the thermostat housing at 260*. waited 30 min got some water from a gas station to fill my radiator and got it home. even though it got that hot i never had a problem afterwards.
lukeciffer is offline
post #10 of 10 (permalink) Old Aug 4th, 07, 12:53 PM
Paul
I changed to a 7 blade fan with a heavy duty rated fan clutch on my 68 Camaro BB 396 and it really pulls a LOT more air through the radiator at lower engine speeds. Runs cooler if you are caught in traffic. I have also been known to turn on the heater on high fan to help cool an engine in hot weather in traffic. You will sweat big time, but keeps the engine from excessively over heating
1962vette is offline
