What radiators fit? - Team Camaro Tech
post #1 of 2 (permalink) Old Aug 5th, 07, 02:51 PM Thread Starter
Question What radiators fit?
I need a cheap temporary radiator. The car is a 69 Camaro with a 327. What radiators will fit out of a junkyard? Need help asap. Little mounting work is okay. I just need one strait out of a car. I heard something about a 95 ford taurus??? Thanks guys.
bullydawg is offline
post #2 of 2 (permalink) Old Aug 5th, 07, 06:41 PM
Dano
Re: What radiators fit?
hi Bully and welcome to TC. I'm not too sure on crossover radiators for a '69 car, but I know that a 68-72 Nova will work. If you have the old one, I would measure mounting hole to mounting hole, then take those numbers with you to the yard and try measure out a few and see if you can get close. Maybe someone in here will chime in with a link to a crossover sheet or something for ya. Good luck
Dano
If you can't see the bright side of life, try polishing the dull side...
MrDanB is offline
