No power to compressor HELP! - Team Camaro Tech
post #1 of 9 (permalink) Old Aug 10th, 07, 06:20 PM Thread Starter
cjg
I could really use some help. Car is all done, factory ac was working fine. Getting last few bugs out and now the compressor is getting no power and won't kick on. Power is getting to switch at controls but doesn't make it out to the compressor. When I touch 12v to the compressor it kicks on. Where and what am I missing? Is there something in between the switch and compressor that could have gone bad that I am missing?
Chris
cjg is offline
post #2 of 9 (permalink) Old Aug 10th, 07, 07:13 PM
click's Avatar
Re: No power to compressor HELP!
chris, what year and make car?
click is offline
post #3 of 9 (permalink) Old Aug 11th, 07, 04:58 AM Thread Starter
cjg
68 Camaro SS396 big block convertible.
cjg is offline
post #4 of 9 (permalink) Old Aug 11th, 07, 10:15 AM
Not sure about stock but on my Vintage Air system there is a switch on the drier that goes inbetween the compressor and the switch inside, this switch disables the compressor if the pressure is not there from my understanding. ie your refrigerant has leaked out so it doesn't allow the compressor to run.
and
Brian Lewis is offline
post #5 of 9 (permalink) Old Aug 11th, 07, 02:41 PM
what brian said...the switch is there so that the compressor doesnt operate without freon, and more importantly, lubrication...the cycled feeon carries with it an oil charge thru the closed system...when there isnt any refrigerant, the oil has nothing to carry it thru the system, so the compressor will be damaged if operated without oil...it could be either empty, or the switch is bad...does the drier sweat, or any hoses get cold when the compressor is activated???
kustomwerker is offline
post #6 of 9 (permalink) Old Aug 11th, 07, 02:57 PM
Tim
77wolf10.85's Avatar
It is a suction pressure sensing switch. You can troubleshoot it by unplugging it and jumpering across the wires momentarily.
Tim Smith
77wolf10.85 is offline
post #7 of 9 (permalink) Old Aug 12th, 07, 05:33 AM Thread Starter
cjg
Thanks guys for the info. I'm looking for this switch you guys are talking about but don't see it. What does it look like? Where is it located? This is all factory stuff and I don't recall this switch.
cjg is offline
post #8 of 9 (permalink) Old Aug 12th, 07, 06:03 AM
Theres no low pressure switch on the old cars. There is a low temperature switch on the passenger side of the A/C box in the engine compartment. This is a normally closed switch that opens when air temperature gets down to 29 degrees or so.
Its probably one of the swiches up under the dash, either the switch on the A/C door (on top of the inner heater box) or the low blow switch on the back drivers side of the control panel. Your going to have to trace it back from the compressor coil thru each switch to find out where the break in the circuit is.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #9 of 9 (permalink) Old Aug 14th, 07, 03:11 PM Thread Starter
cjg
SUCCESS! Thanks to everyone who helped. Mark you were close. It was the ambient temperature switch. Bypassed it and we have ac. New switch on the way.
Thanks Camaros.net
cjg is offline
