fan shroud depth on a 67/68 BB - Team Camaro Tech
post #1 of 30 (permalink) Old Aug 14th, 07, 12:02 PM Thread Starter
Johnny
wondering if some of you guys out there with an original 67/68 BB can measure the length like I have in the picture and let me know if 6 1/2" is correct, so I can eliminate this as a problem as to why my fan does not go halfway into the shroud. thanks,
http://
67Camaro 396BB 750Holley, edlebrock performer,280isky,3.42 posi, turbo 350,stage 2 shift kit, 2800 stall, MSDready to run distributor, headers, 2.5"exhaust, Hotchkis(1.5"/2"drop).(orig.Deep water blue/light blue dlx inter, v8 column shift/bench seat)
johnny67 is offline
post #2 of 30 (permalink) Old Aug 14th, 07, 03:17 PM
cjg
Re: fan shroud depth on a 67/68 BB
I've just run into this problem because my 68 BB was overheating. It was because the fan didn't go into the shroud enough. New shroud, fan and an electric fan and we're golden. The measurement though, exactly like yours, is 7 1/2 inches. Is your car overheating?
cjg is offline
post #3 of 30 (permalink) Old Aug 14th, 07, 08:05 PM Thread Starter
Johnny
yeah cjg my car is overheating on hot days and I suspect its because of the fan not being in the shroud. Why am I only at 6 1/2", compared to your setup? 7 1/2" would put my fan in the right spot
I swear I ordered a 67/68 shroud last year.
Do you have any pictures
johnny67 is offline
post #4 of 30 (permalink) Old Aug 14th, 07, 08:22 PM
bill
johnny you most likely got the wrong fan clutch on there.theres 2 different ones. and the difference is length of it. it was posted couple of weeks ago to help you out.
hereitis67 is offline
post #5 of 30 (permalink) Old Aug 14th, 07, 08:38 PM Thread Starter
Johnny
thanks but I checked out the hayden site and a 2710 is what they suggest will work. It is 1.75" in length from mount to mount, so I checked mine and it is 1.75 so I am still confused.
johnny67 is offline
post #6 of 30 (permalink) Old Aug 14th, 07, 09:18 PM
That sure looks like the right shroud.
Why not put a 1" spacer behind that fan clutch?
post #7 of 30 (permalink) Old Aug 14th, 07, 09:25 PM
phil
i'm 7 1/4 and the fan sets in more orig rad and shroud
rare4k is offline
post #8 of 30 (permalink) Old Aug 14th, 07, 10:56 PM Thread Starter
Johnny
Thats in the same ballpark as cjg at 7 1/2". What looks different on mine compared to yours? so I can get my mystery solved
thanks but I want to stay with a stock set up Jim. So a spacer is out of the question.
johnny67 is offline
post #9 of 30 (permalink) Old Aug 15th, 07, 03:51 AM
cjg
I will let you know which shroud I got. The first one was like yours and I had the same result as you. So, I had to get another that is still stock. Let me get back to you.
cjg is offline
post #10 of 30 (permalink) Old Aug 15th, 07, 09:01 AM
cjg
It's a 68 Big Block shroud from Rick's First gen. It helped me bring the fan in an extra inch. Good luck man. It's working for me in Florida with A/C during some 100 degree weather.
cjg is offline
post #11 of 30 (permalink) Old Aug 15th, 07, 02:25 PM
Wow, like you guys were reading my mind. I have the same prob. 67' small block, long pump, still an inch shy from getting to the shroud, let alone deep into the shroud. I didn't want to add a spacer to the fan clutch because it looks like it will wabble. I too have the overheating problem. So I guess my Q is can I add possibly 2 spacers to get my depth, or say screw it and put the electric fan. I'm becoming truly aggravated attempting to fix the problem. Thanks
GAccomando is offline
post #12 of 30 (permalink) Old Aug 15th, 07, 06:49 PM Thread Starter
Johnny
thanks cjg, what was your conclusion about your old shroud? do you think that it was a 69' or just a bad repo?
Is it possible to post a pic with a tape measure of your shroud like mine. It would be greatly appreciated
johnny67 is offline
post #13 of 30 (permalink) Old Aug 15th, 07, 09:04 PM Thread Starter
Johnny
I think I may have come up with the solution and it is a little . I was looking at a picture of an original BB 67 camaro, and the shroud seems to be bolted to the top bracket farther out than mine. So if it's okay not to have the shroud 100% up against the rad and out maybe 1/4" that will bring my fan halfway in. The only problem will be a hole in the shroud where it was bolted.
http://
http://
johnny67 is offline
post #14 of 30 (permalink) Old Aug 16th, 07, 02:27 AM
cjg
Johny,
I don't know what year it was. Just knew it wasn't gonna work, car was over heating. Bought the proper one for the car and it worked. I'll get you a pic.
cjg is offline
post #15 of 30 (permalink) Old Aug 16th, 07, 10:28 AM
phil
OK, !!!! who's L78 is that in the pic that johnny has ?
rare4k is offline
