Big block fan clutch clearance problem - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 20th, 07, 07:31 PM Thread Starter
I'm putting together a 69 Camaro COPO clone with a iron head 427. I'm using the curved neck 4 core radiator, standard long water pump. I don't have room for the 7 blade fan and fan clutch. Fan clutch measures 3.4375" total height. It hits the radiator. Does anyone know if there's a thinner clutch out there. I've tried Ricks, Classic, I even called flex-a-lite for advice. Everybody says it's a tight fit but there's got to be something that can be done. I want to keep it stock appearing but I'm running out of options. Anyone have any ideas? Thanks for the help.
cmcjwn is offline
post #2 of 3 (permalink) Old Aug 24th, 07, 09:02 PM
Re: Big block fan clutch clearance problem
I have a 69 COPO Clone with a 70 LS-6 454 in it. I have a curved neck rad with a fan clutch. I can get a part # and measurements if you need them.....
leo4321 is offline
post #3 of 3 (permalink) Old Aug 26th, 07, 06:26 PM Thread Starter
Thanks but I was able to find a clutch that measured 3.09". I was able to get about 7/16" total clearance between the radiator and the front edge of the clutch. Appreciate the help though.
cmcjwn is offline
