fan shroud? - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 21st, 07, 05:48 AM Thread Starter
Big daddy
fan shroud?
Hey guys,I have a 67 setup with a 3 core 23" rad,it is set up like a 69 with the alt on the pass side and long water pump.The shroud does not cover the complete rad.I think it was for a 21" rad.Can I use a shroud for a 69 sbc that will cover the whole rad? Thanks
67ssclone 383 4spd 3.73 vintageair
carhodge is offline
post #2 of 3 (permalink) Old Aug 21st, 07, 06:07 AM
Re: fan shroud?
best I think would be a shroud for a 67-68 small block car w/AC. This is a 23" shroud with the fan hole centered for a small block.
That shroud will be 1" deeper than the 69 style long pump setup wants, but it should work ok. It will certainly work better than an "ultra short" "offset fan hole" big block shroud, and no 69 small block cars had a 23" radiator, so the shroud you really need doesn't exist.
post #3 of 3 (permalink) Old Aug 21st, 07, 06:16 AM Thread Starter
Big daddy
Re: fan shroud?
Thanks Jim that was quick,Now does anyone out there running 67-68 ac shroud like Jim mentioned?
carhodge is offline
