Intake manifold Electrolosis - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 22nd, 07, 12:39 PM Thread Starter
Removed the t-stat housing yesterday to install a high flow t-stat. Inside the intake under the housing appeared to be a small amount of barnacles multiplying on the intake walls. Assume this is eletrolosis disintigrating the aluminum intake because of the dissimilar metals especially because of the chrome t-stat housing and iron block. I've heard a zinc anode installled in the radiator petcock hole will eliminate this action??? Anyone experienced this with their engines?
Chevy Chase is offline
post #2 of 4 (permalink) Old Aug 23rd, 07, 09:38 AM
Codi's Avatar
Re: Intake manifold Electrolosis
Typical arguement between aluminium and iron/steel. There are several products on the market you can add to your coolant that will cut down on this as well as an anode attached to a radiator cap. The anode is sacrificial and will disintegrate over time leaving the aluminium alone. Adding something like a water wetter or such can also help.
Daddy's Hot Rod.
Codi is offline
post #3 of 4 (permalink) Old Aug 23rd, 07, 01:41 PM
Steps
Good quality Anti freeze also has anti corrosion agents....
This should be changed once a yr when doing raditor cooling system maintaince, same as one changes oil/ filters on a regular basis
Steptoe is offline
post #4 of 4 (permalink) Old Aug 23rd, 07, 06:01 PM
GM makes some good anti corrosion pellets , crush two or three and drop in radiator. Large brown pellets.
TC # 349
zdld17 is offline
